I have a Kohler KT17 series II that's out of a 782, it's now in a John Deere 317 (purchased like this) Model KT17 S, spec 24302
I have a bad coil, and have checked with meter, and also replaced coil with a known good coil, and it is the coil. I have searched several times with not much luck, are there any replacement coils like Bosch (the blue one everyone raves so much about) for a KT17, all I have found is OEM stuff.. I don't really want to run two coils. Thanks, Clint |
You might try this.... http://kirkengines.com/index.php#DualSuperCoil
I seen that, actually pretty much the only alternative to the OEM which is $100 +(+), I have never dealt with this company, however I have seen the website/name mentioned mostly the points saver which always gets good reviews.
I also have seen the transistor breaker-less system that replaces the points, looks like a cool idea, but points are not that bad, and even though I despise them (much prefer electronic ignition) points seem to last a very long time with very little problems. Roland have you had any dealings with http://www.kirkengines.com ? also what are your thoughts on the transistor breaker-less points slayer ? Thanks Clint |
David Kirk is A+. Quality work, quality parts, and quality business.
![]() ![]() I will second what Mr.Bedell stated. I have purchased several parts from David Kirk, great quality parts and performed as described, also great instructions with the parts. I will continue to purchase parts from him as needed. Don B. |
