Old 05-07-2012, 12:47 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Default Coil issue maybe
K321
This is the 149 I brought home Friday. Should I here a very slight snapping sound from the coil when the key is turned on?
That's what I hear when I turn the key just to ON. Dust on top of the coil even jumps a little. What's up with that?
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 05-07-2012, 01:56 PM
Originally Posted by yesmar74 View Post
K321
Doesn't sound right to me. Is it an aftermarket coil? either way sounds like it's going bad to me.
Old 05-07-2012, 02:25 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Never heard that from any of the coils good or bad. But like Duke said, its probably going bad. If it's not a Kohler coil, it will shortly anyway
Old 05-07-2012, 03:02 PM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
If you can get the tractor into a dark area (or wait until tonight) do a visual check in the dark and watch for a spark trail outside the coil tower. A crack in the tower, or a conductive path from the inside of the tower to a ground will divert the spark away from the plug wire.
Check for a crack in the tower, clean the inside and outside of the tower to assure no oil / grease / dirt path is diverting the spark away from the plug wire.
A little spritz from a water bottle onto the top of the coil may aggravate the problem and make it easier to find the "spark leak" from the tower area. Something is making it electrically easier for the spark to jump out of the coil to ground than jump across the plug gap.
If you do not learn something new every day ... you are not paying attention !
Old 05-08-2012, 07:14 AM
yesmar74's Avatar
I got the old girl started yesturday after noon. Had already set the timing and changed the points. Put on a new condensor and cleaned the coil tower real good. I don't hear the snapping sound now and it starts and runs. I'm not sure what the fix was but it's running. Time to give the carb a good cleaning and maybe rebuild. Atleast I was able to see if the hydrostat and lift operate OK and they do. All the hydro linkage seems in good shape and reasonably tight. Push the the brake down and it dosen't even creep. I'm going to need a muffler as this one is blown out. I used to like LOUD .Thanks for all the help.
Old 05-08-2012, 12:23 PM
Great pics! Glad you got it fixed.
Old 05-08-2012, 01:07 PM
Same here!
