Old 05-13-2012, 06:33 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Default 2 bottom plow?
Was wondering if anyone on here had built or seen, has pictures of a 2-bottom plow for a cub or equivelant. Looking at building one of my own and have another guy that wants me to build one for him out of two 10inch brinly's next fall. Looking at which style of plow setup would be best for our cubs (semi mounted 3pt, just straight 3pt, pull behind etc). Inputs appreciated Thanks.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 05-13-2012, 06:38 PM
Shaner Shaner is offline
someone had a 2btm plow on a sears tractor a while ago down here. ive been thinking about making one but id have to get at least one plow first.
Old 05-13-2012, 06:40 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Someone on here did it before, maybe they can post a pic of it.
Old 05-13-2012, 07:04 PM
RandyD RandyD is offline
Here is a pic of a JD 2 bottom plow set-up.
Old 05-13-2012, 07:08 PM
Thanks for posting that as I couldn't find the thread on it.
Two more threads for you to view.
http://www.onlycubcadets.net/forum/s...ht=bottom+plow
Old 05-13-2012, 09:10 PM
jlampe94's Avatar
Thanks guys its helping the ideas. Going to make it out of two 6inches first. Thinking on just a straight 3pt mount. Do ya think i would need any adjustments on the plow itself like a brinly or would the 3 pt have all the adjsutment it would need?
Old 05-13-2012, 10:02 PM
maddog784's Avatar
I think you're going the right way with a fully mounted - every pound of weight on the back tires will help you, and that's something that a pull behind plow wouldn't provide. A semi mounted might do alright, though. I would expect all of your draft control would have to be in the top link of the 3pt. A gauge wheel might help with the draft control. Looking forward to this - when you accomplish this awesome task, give us a video!
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-13-2012, 11:31 PM
jlampe94's Avatar
Ok, yea hopefully ill have hydraulics by then on my 1200 and have a hyrdaulic top link too. Forgot about a guage wheel. Is uploading a video the same as a picture?
Old 05-14-2012, 07:32 AM
Darrell Darrell is offline
Here is a short video of an O pulling a two bottom plow. Says it has a 20HP engine swapped in it.
http://www.youtube.com/watch?v=ZKQFfVxLBQs
Old 05-14-2012, 04:49 PM
Merk Merk is offline
by Darrell
It does have a 20 hp engine in it.
The video was taken at Ohio Plow Day north of Findlay, Ohio.
The owner is a good friend of mine.
