Old 05-14-2012, 11:17 PM
LukeH's Avatar
LukeH LukeH is offline
Default CCO mower deck question again
So I got my pulley that connects to the engine and spins the blades. I have been adjusting the tension of the pulley with the big bolt that goes across the front. Now the problem is when the belt is connected I cant get the blades to disengage they are always spinning, is there an exact tension I have to have on the belt or what?
Old 05-15-2012, 09:16 AM
PaulS's Avatar
PaulS PaulS is offline
The pto belt for the O is always running. The blade shutoff is on the mower deck itself. I do not recall what adjustments can be made on mower belt tension but do know the mower belt itself is a toothed belt and the blades must be timed with one straight ahead and one side to side or the blades will hit each other.
Old 05-15-2012, 12:40 PM
LukeH's Avatar
I understand the timing thing but the blades are always spinning I cant turn them off.
Old 05-15-2012, 12:53 PM
maddog784's Avatar
Sounds like you need to adjust the linkage from the foot pedal on the deck, as it sounds like it's set too tight. Also, make sure you have the correct belt going from the middle pulley to the left hand blade spindle. Too small a belt won't allow the middle pulley to disengage.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-15-2012, 01:06 PM
LukeH's Avatar
Thanks it might be the linkage ill have to look at it more.
Old 05-15-2012, 05:33 PM
mmzullo mmzullo is offline
Do you have the pulley covers? I think the belt guard had a piece that stopped the belt from spinning once tension was released
Old 05-15-2012, 08:00 PM
LukeH's Avatar
Ya i got the covers maybe there is a piece in there that is missing.
Old 05-16-2012, 07:53 AM
There is a semi circle piece under the cover that looked like a horse shoe.
Old 05-16-2012, 11:35 AM
LukeH's Avatar
Ok Ill look at it today. Do you have a picture that you can post showing exactly where it is?
