Old 05-15-2012, 06:42 PM
IH Cub Cadet IH Cub Cadet is offline
I like the QL series tractors. Of course I'm biased, I've got a 1650. As best I can tell, the thing that turns off most is ISO mounts get squishy and need replaced. I don't consider this a big deal. Other than that, I feel they are a very good tractor. I like the looks of them too. They strike me as an interesting combo of new and old. They are definatly rock solid/heavy duty, but were the first Cub Cadets to have an enclosed engine compartment and electric actuated PTO.
I think your 1250 is a fine machine - keep it!
Also...
Good luck,
Bill
Old 05-15-2012, 08:54 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I have a 1250 that was not given attention as it should have. After I got it, I looked on this site and saw what areas to watch out for as trouble spots.
I just recently got it in service again after replacing those items that are common problems with these tractors. You can search this site for my posts about working on my 1250. Just look for my member name, bllwnkl.
This group of guys on here helped me out tremendously, and they will help you, too. Keep it and good luck!
Old 05-15-2012, 10:03 PM
VIOLATOR VIOLATOR is offline
I have a 1975 1450 with a 16hp kohler engine in it. I am the second generation to own it. I have had a few little problems with it but nothing serious. And nothing that you would not expect from a machine from the 70s. But it is a great tractor. The guys on this site have been very helpful with helping me get my tractor fixed and with trouble shooting
Old 05-16-2012, 07:28 AM
steveyrock's Avatar
steveyrock steveyrock is offline
My 1250 had everything wrong with it when I got it but even still it ran and mowed.Here is the list of what it needed.
Engine rebuild,bored .010 over with all Kohler parts.
ISO mounts and cradle modification.
Gasket behind hydro pump.
Trunion repairs and springs.
New relief valves.
Muffler crutch and heat shield repairs.
Wireing and switch gremlins,chargeing problem rooted out.
Cooling fan and ragjoints.
New front tires.
New battery points plug and condenser.
Steering work includeing a nicer wheel.
New PTO deck belts.
around 1200.00 total investment,but I saved it from being tore down for parts and I hope I never need to buy a box store machine.
forgot to mention my time in hours but I love that stuff.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 05-16-2012, 12:11 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
I've got a 1450 and found the ISO rubber engine mounts are the most likely trouble spot. I was fortunate in that the previous owner replaced them not long before I bought the 1450. I did get the crack on the aluminum exhaust box welded, and that is a common situation, and why the 'muffler crutch' was invented.
Some have mentioned the driveshaft, but I'm not sure what about it is a possible problem.
I also have two 149's and it is remarkable how much quieter is the 1450. In the long run, I think you will be happier with the 1250 than a Narrow Frame.
Old 05-16-2012, 01:35 PM
OK, I give up,
what is a muffler crunch!!??
Pics please, I - am - s-l-o-w !!!
Old 05-16-2012, 01:47 PM
All of the drive shaft problems that I know of are ISO mount related.
Old 05-16-2012, 03:11 PM
dje22's Avatar
dje22 dje22 is offline
This is the crutch
David
1200 w/ 44in deck
1000 w/ yanmar diesel.... in progress
Old 05-16-2012, 03:14 PM
dje22's Avatar
Oops try this again....
David
1200 w/ 44in deck
Old 05-17-2012, 12:46 AM
Cub-N-It's Avatar
Cub-N-It Cub-N-It is offline
All vintage LAGT's have their own set of issues. None are issue free. The good thing about Cubs is there are replacement parts galore, and good people on sites like this one to help you work through the issues. Where you have to be concerned about issues is with an old Simplicity. From what I can tell, there is no support group for them like there is for CC, Wheel Horse, and JD.
