Old 05-16-2012, 06:05 PM
cdlong's Avatar
cdlong cdlong is offline
Default Finally got the 1450 hydro right!
I had replaced everything in the hydro linkage that was recommended here. I still had the slow down uphill & speed up downhiil problem. THEN, I got my tiller. Not being able to hold a steady speed tilling is a royal pain. I went thru every post here that mentioned hydros. I found a post that said "everything must be tight". I removed the fender pan and mine wasn't. A trip to Sears Hardware for shims and wave washers cured the problem. Now to find another garden to till! Never,never,never give up!
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 05-16-2012, 10:17 PM
Thanks for the pics! Now you can really enjoy the 1450!
Old 05-17-2012, 12:04 AM
Awesome news!
Old 05-17-2012, 12:16 AM
Cub-N-It's Avatar
Cub-N-It Cub-N-It is offline
Yep, its a good feeling to get it running right!
Old 05-17-2012, 02:45 PM
jluster jluster is offline
Do you have the member or direct link to the thread you are referring too? I have a 1650 and a 882 with lots of slop. I press the brake and the thing moves forward. To get to neutral, the hyrdo control actually has to be in reverse.
129, 109, 1200 x 2, 1650, 882, 1450
2A tiller, 50" & 44" decks
Brinly 12" plow
Brinly Disc Harrow
Snow Plow
Joe Luster
Cincinnati
Old 05-17-2012, 02:55 PM
Go to the tractor tec. portion of the site and down load the service manual, it's all in there.
Old 05-17-2012, 03:48 PM
jkier's Avatar
jkier jkier is offline
You can jump across the bridge and do mine!
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 05-17-2012, 04:51 PM
cdlong's Avatar
Be more than happy to come help ya!
CD 302-690-9046
Papaw
Old 05-17-2012, 05:13 PM
krhoover krhoover is offline
Do you remember what the ID was of the shims you bought? I didn't kinow sears had a hardware dept. that sold that kind of stuff. I'm going to have to check it out.
Old 05-18-2012, 03:51 AM
cdlong's Avatar
It's a Sears hardware store, not a regular Sears store. They have 2 size shims in 9/16 & 5/8. I bought 2 of each and 4 of both size wave washers. I think the 9/16s were 61 cents each & the 5/8s were 81 cents each.
Papaw
