Old 10-31-2009, 12:14 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Default Looking at a 127, things to consider?
I'll be looking at a 127 soon, and like to know what I should look for, or what would be a deal breaker. Any input would be welcomed.
Here's what I know:
It's a 1972 127 Hydro. He says it "blew" the engine, but after I called him, he said it was a cracked tooth on the camshaft. He said he shut it down when it first started clicking, so the damage might be minimal.
He had taken it to a shop, they tore it down, went out of business, and returned a box of parts. Then engine is out of it, and presumably disassembled. I'm not sure how disassembled it really is. I'm thinking basket case.
He said it has been painted blue by a previous owner, but the paint isn't too bad.
Supposedly the deck has been gone through and all the bearings are good. The mower deck supposedly mows very well.
He put a new seat on it, replaced the brakes and fixed the loose steering before it shelled the engine.
He sent me a picture, but it's very low resolution, and you can tell it's a lawn tractor, that's about all.
Anyone ever heard of a cracked cam gear? Would that wreck the crank gear? Is the crank gear replaceable if it is damaged? Would this year of Kohler have had the plastic governer and possibly balance gears?
Sorry for all the questions, but I value your judgement. Also, is there anything else I should look for that would be a deal breaker?
He wants $300 for it, and won't budge as he said he'd keep it and rebuild it at a later date. He bought a simplicity to replace it for now.
Thanks all!
Jim
Old 10-31-2009, 12:30 PM
Hi Rhoderman,
He wants too much. I definitely wouldn't pay $300 for it. With the engine out, you can't see if the hydro works. Plus, there may be other problems. I'd look for another Cub Cadet.
Old 10-31-2009, 12:55 PM
metalrain metalrain is offline
Yup...i agree...300 is way to much...just a couple of years ago i bought a nice running 125 with a snowblower for 250.
Its not that i got a good deal....its a basic price. replacing/overhauling a motor will cost you some bucks....and as ACecil says....you don't know the shape of the hydro....better deals out there.
Metalrain
Old 10-31-2009, 12:58 PM
MrChic's Avatar
MrChic MrChic is offline
Yikes, I wouldn't pay $300 for it. Sounds like a total parts machine. Offer him a $100 or maybe $150 (too much for me) and walk away. If he wants to rebuild it, more power to him. I had a guy local to me selling a 147 w/ electric lift for $175 and it ran. Some fool had tried to make it a red tractor. So he was selling it cheap.
Mike
1968 CC 105
"Chug a lug a luggin' 5 miles an hour on my International Harvester"
"Don't forget that ignition key !!"
Old 10-31-2009, 02:28 PM
RPalmer's Avatar
RPalmer RPalmer is offline
I agree with all the others. You are looking at a roller. And like was already said you can't check out the hydro or electric. Pass unless you want to spend a lot of money to restore it. It could cost a lot just to patch it. Starting with a different engine.
Old 10-31-2009, 05:44 PM
Merk Merk is offline
I have never heard of a cracked tooth on the camshaft. Something had to get against the cam or valve(s) to stop the movement to crack the tooth.
Offer him a $100 like MrChic said. You will spend $300 to $400 to rebuild the motor right.
Old 10-31-2009, 05:59 PM
I have heard of the balance gears taking out the cam, but I don't know if your engine would have had balance gears..
Old 10-31-2009, 06:03 PM
Rhoderman's Avatar
It must be nice to be out there in Ohio and NY where Cubs are a dime a dozen...
I can't seem to spot many of 'em out here in Colorado. $300 is a cheap one here, and they're usually beat to death.
I'll probably go take a look at it, and maybe show him a printout of this thread to try to get him to budge. I guess a lot of it depends on where you are and what else is available.
Thanks all! I really appreciate it!
Jim
Old 10-31-2009, 06:47 PM
RPalmer's Avatar
Rhoderman
They aren't really a dime a dozen. But on a good day you could pick up a dozen for 3.6k
Old 10-31-2009, 06:56 PM
CubQuest CubQuest is offline
Well to begin with I can't be a 72, the 127's were built between August of 69 and August of 71
The 127's were built during the transition period when Kohler just started using the balance gears and some had them and others didn't. I have 2 127's, one never had them and the other has had them removed. If the engine has the long dipstick on the right side of the block it never had them. The gears would be in the way and the dipstick wouldn't reach the bottom of the pan. If it has a short stick on the left side and an oil fill on the right them it left the factory with the gears.
