Old 05-19-2012, 01:00 AM
cavmedic cavmedic is offline
You can also check the adjustment of your deck hangers. They may need some small adjustment to help level it up from the front and even the air pressure in your tires to help level things out. I've used a torpedo level before to help me with this and was very pleased with the results.
I have not checked the TP . I have all 4 tires filled with fluid and assumed they are good since they were done at a New Holland AG dealer.
I'll add that to the list.
Old 05-19-2012, 08:42 AM
Here are two shots of what it looks like ....
The one on the left was cut both ways to make it look semi decent, the one on the right, I ran out of day light to go back over it.
Old 05-19-2012, 07:45 PM
Also, is the deck worn to the point where the blades are moving vertically when mowing? I've had a deck with metal so thin it would do that, and make the cut look terrible.
Old 05-19-2012, 08:00 PM
The deck is really meaty.
I pulled my gators off and put my others on , and was looking at the blade tips. There was a half inch difference between all three blades. I shimmed them to all match and re-mowed and it looks pretty good now.
The only bad thing is when I shimmed , it cut shorter now. I have to re-adjust the height as it is too short now. I wont be able to tell anything more until next week when it is time to mow. But I think I got it pretty good now.
Old 05-19-2012, 11:18 PM
Donovan M.'s Avatar
Bigger engine
Donovan:
62' Original-fenders
Old 05-20-2012, 05:35 AM
Originally Posted by Donovan M. View Post
Bigger engine
No more ideas like that..........
Old 05-20-2012, 08:18 PM
I have a welder , drill press and cut off saw. Want to drop in the engine from your Trailblazer
Good to hear you got it straightened out
Old 05-20-2012, 08:20 PM
Not the tb , but the bike is a possibility. I don't think the neighbors would appreciate me mowing the lawn tacking at 11k though.
