Old 05-26-2012, 12:59 PM
JPWright JPWright is offline
Default My home made carryall
I saw few “carryalls” on different sites that hook up to a sleeve hitch, and liked the concept for getting wood up the hill without high lifting and having good maneuverability in the woods. I built mine with an angle iron and T-iron frame (from a free garage door opener). I bolted ¾ inch plywood to the frame. I was very concerned about breaking my cast lift arm so decided to suspend the sleeve hitch with chains by adding a piece of T-iron in my tool box. The thing works great for getting those large rounds of elm up to where you can get at them with a splitter. The weight limitation for the carryall is determined by the front wheels coming off the ground and loss of maneuverability.
My 122 has fluid in the tires and wheel weights so no problems climbing any grade.
A 122 with weights and a deck for mowing trails.
100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing.
100 with weights for wood hauling.
Rusty functional 102 with rear lift.
Elec Trac E15 for finish mowing.
Old 05-26-2012, 08:22 PM
Looks good but I'd be more concerned with four 3/8" bolts in some sheetmetal than breaking a cast iron lift arm.
That log can't weigh more than a tiller
Old 05-26-2012, 09:10 PM
My thoughts exactly.
Old 05-26-2012, 10:25 PM
Looks like it'll do the job, dig the swivel seat
Old 05-26-2012, 11:16 PM
Nice job! Thanks for the pics.
Old 05-28-2012, 07:38 PM
Sounds great. I would like the carryall to tip up and down. I will give it try with the lift. Thanks for your suggestion.
Old 05-29-2012, 12:35 AM
inspectorudy's Avatar
I had Aaron make me one at Extreme and then I added a plywood shell for the hauling of things like blocks or bricks. It does rise and fall with the lift and comes in handy when I need to get under something that is too heavy to lift onto the platform.
1811 Hydro
