Old 05-30-2012, 09:35 PM
lukeott lukeott is offline
Default Rear PTO ?
Wanting to add rear pto on a 982 rear. Which one or ones will work. Also, down the line would like to add on cat 0 lift. I don't see where that matters but thought I'd add that. Thanks for your help.
luke
Old 05-30-2012, 09:46 PM
You have to have the Cat-0 lift to use the 3-point, and only the 3-point and rear PTO from another super will work. If your 982 has a cast iron rear, the rear cover plate you'll need must be from a 982 if the rest of the PTO came from a later tractor with an aluminum rear.
Old 05-31-2012, 06:47 AM
toyman's Avatar
toyman toyman is offline
luke
Matt is correct about the rear cover plate. My rear pto came off an 1872 and had the cover for the alum rear. I took a cover plate from a ci rear and fabricated the pto cover plate. Works great and the covers for ci rears are relatively cheap and available. Also, as far as the 3 pt goes, Ruegg makes a 3 pt like the original for use with the rear pto, if you can't find one used. I posted a thread when I did the install on my 982.
Original Member #54
Old 05-31-2012, 09:27 AM
Default Confused a little
Not quite sure what I'm reading, sorry. Let me say I haven't started this project yet and I'm really going to struggle with it. I bought a 1572 with a cracked aluminum rear. I purchased a 982 cast iron rear to put in it's place. Now I've decided to put rear pto on while everything being changed over. So I want to be sure that all the parts I get will be right. Also would like to put on 3pt hitch on in the future ( probably can't afford right now). Trying to put all my ducks in a row without mistakes. Also thinking I'm going in the wrong order because having the 3pt hitch first makes more sense.
luke
Old 05-31-2012, 01:35 PM
maddog784's Avatar
If you still have all of the internals from the aluminum rear, they will fit into the cast iron rear. The internals from the aluminum rear are stronger and have fine splined axles. Also, the axles have studs on them - makes tire removal/replacement a little easier. The cast iron internals have a bevel cut ring and pinion, while the aluminums have a straight cut, so if you decide to switch these out, you'll have to change out the pinion shaft or swap the ring gears. I swapped everything for my 982, pinion and diff, and it works great. Just my
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-31-2012, 03:38 PM
Default Any pictures
Hey Maddog, Did you happen to take any pictures of your project? Would help me to get a visual. Will try to do a search to see if there are other rear change outs.
luke
Old 05-31-2012, 05:45 PM
ajgross ajgross is offline
Inactive Member
If you use the 982 rear end, you'll need the cover for a pto rear end. Good news is that http://www.ihccw.com has a plate that will fit your needs. Look under the Front and Rear PTO section and look for a red plate labed "USED REAR COVER PLATE ASSEMBLY IH 135616 C2 703-0449". That is the cover you need. After you get the cover installed, you can start looking for a complete pto setup. They are hard to find and usually cost around $500 to buy one, but once you have the correct cover installed, then you don't need to get back into the rear end to install the rest of it. Everything else is external.
AJ
Old 05-31-2012, 06:36 PM
AJ, I tried contacting Ruegg a few months ago and never got any response. Are they still making them for the Cubs?
Old 05-31-2012, 08:17 PM
wally67's Avatar
wally67 wally67 is offline
Ruegg is still making them I ordered one for my 2072 about 3 weeks ago but havent got it put on yet looks to be a nice piece.
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 05-31-2012, 08:40 PM
Just looked at the Ruegg web site, says only JD. , are you sure they make them for Cubs?
