Old 06-07-2012, 02:09 PM
NCDiesel NCDiesel is offline
Default One clip too big, one too small and the middle one is NOT "just right"
Rebuilt my barb and went to install it and realized I had lost my e-clip that secure the carb throttle rod to the governor arm. So I went out and bought a few in each of the sizes I could find at the hardware store that seemed in the right range :
1/4 clip - too big
1/8 clip - too small
3/16 clip - Close but still too big and falls off easily and too thick for groove too!
What size is that clip?
I could have sworn it measured 3/16 but a 3/16 definitely does not fit. I guess maybe it could still be a 3/16 if the cheap chinese clips are out of tolerance .
Thanks in advance!
NCDiesel
Old 06-07-2012, 04:53 PM
jkier's Avatar
jkier jkier is offline
I hate those E clips, I cut a small piece of 1/8" fuel line and slip it over the end of the throttle rod behind the governor arm.
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 06-07-2012, 06:15 PM
It's 5/32", which is between 1/8" and 3/16".
Old 06-07-2012, 07:03 PM
Thanks! Of course, that is the size NOT available anywhere locally. Everyone seems to go 1/8 - 3/16 - 1/4 The fuel line is a good idea, though I was using a zip-tie to hold it but decided I was done with half-measure solutions. I thought buying one would be easy. That is what I get for thinking (-:
I guess I'll order online. Thanks again,
NCDiesel
Old 06-09-2012, 12:29 AM
ole 147 ole 147 is offline
Try going to a place that has lawn tractors. Sell or repair shops. Buy it for the engine not the tractor.
any 10 or 12hp they used the same for the yr and hp. as long as it's the same make. It's a good idea to take the S N for the engine. That's how I find engine parts I need.
Old 06-10-2012, 01:40 PM
jcsmith jcsmith is offline
Default e-clip
same thing happened to me. I started rootin' around my junk drawer and came across several carb linkage clips from an auto carb rebuild kit and I had 1 that fit perfect. Way better than the oe clip.Don't have a camera, I know a photo would explain it much better , but I'll try. The clip has 2 holes in 1 end. It goes over the end of the governor arm, then the L -bend from the carb goes thru the 2 holes, then swivels down and snaps onto the linkage to carb. Hope this helps.
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
