Old 06-11-2012, 05:38 PM
restore49 restore49 is offline
You may find that with such a small change needed(untwist) there is no need to heat.
Old 06-11-2012, 07:37 PM
I would advise not to keep twisting the metal back and forth as it will make it weaker over time. If you don't get the right you'll smoke your belt.
Old 06-12-2012, 11:41 AM
Ash_129 Ash_129 is offline
Agreed.
I did the same (flatten) to my brackets. The previous owner ran the deck drive to a 38" cut deck, even though the deck drive was for the 44" and 50" deck.
I disassembled the drive, removed the pulleys, and flattened the brackets in a 20 ton press. No heat needed.
Cheers
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 06-16-2012, 01:08 PM
ab147's Avatar
ab147 ab147 is offline
I don't want to open a can of worms here, but I've run my tiller with the mower deck mule on a 147 for 23 years and haven't had any problems. I have recently put the tiller on a 149 and am using the mule from that mower deck also.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 06-16-2012, 02:43 PM
Nah, your not opening any worms. But your mower mule drive is a completely different design than the one he has. You can use your's without issue.
Old 06-19-2012, 06:52 PM
aircowboy2008's Avatar
aircowboy2008 aircowboy2008 is offline
is it the same for a 1650 with a 50 inch deck
Old 06-20-2012, 10:14 AM
Do you have a tiller as well? If so you need to the 38/42 mule drive. If no tiller then you need the 44/48/50 mule drive.
Old 06-20-2012, 08:25 PM
I have a 2 tiller i'm wanting to use and 50 inch deck that i mow with now
1650 with 50 inch deck
122
149
#2 tiller
Old 06-20-2012, 09:21 PM
Peruvian Peruvian is offline
I have a separate mule drive for my tiller than for my 44a mower deck. I have a 1250 and 1450. You only need the front part of the mule drive and not the mower hanger if that helps when you are looking.
Tags
1450, 44a deck, mule drive, tiller
