Old 06-06-2012, 02:45 PM
Shaner Shaner is offline
the tractor isnt for sale locally...im the only one that knows about it right now. im picking it up next friday. ill be sure to get pics when i get it. he said the oil seal behind the PTO leaks...how hard is that to replace? i can't imagine itd be any different than a seal on the creeper gear i replaced on my 122.
Old 06-06-2012, 03:56 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Not too bad, getting the old seal out will be the challenge. I would pull the exhaust to make it easier to get at.Unplug the PTO, (3) bolts hold it to the closure plate. It also has a bolt going into the crank. once those are removed, a little bit of wiggling should get it off. Then the seal is right in front of you.
All of this is after removing the grill shell, hood, side panels, and front motor tins.
You said it had a M18 in it? Here is a link to the sevice manual;
http://www.onlycubcadets.net/forum/s...ead.php?t=4648
Old 06-09-2012, 02:38 PM
i went and checked it out today. in pretty decent shape. brand new Carlisle true power 10.5 ag treads on the back so thats a plus. comes with a Giant Haban snowblower thats in decent shape...the snow blade is SPOTLESS! tiller is in okay shape. deck is in good shape. hub caps are a little rusty and one has a big dent in it but nothing a body shop can't fit and ill have them rechromed and put on my girlfriends stepdad's restored 1200. i found the serial tag on it
model: 143782399
serial: 2050601U716015
anyone know the year? i know its a CCC model not IH which is a downer but still its a 782
Old 06-10-2012, 06:58 PM
young enthusiest's Avatar
How could anyone ask $450 for a tiller?!!! I've bought $50 tractors with tillers. 2 tractors and 2 tillers for $400... I've got 9 tillers now, any takers?
once you get that 782 everything else you have wont get used. Those tractors are just the most beautiful looking a driving thing ive ever seen. congrats!
Old 06-10-2012, 09:59 PM
Shaner,
It is a 1983.
Old 06-10-2012, 10:23 PM
Tyler,
$450 is for everything. Grrrrrreat deal...
Up to 534 and counting...
Old 06-16-2012, 02:16 PM
well i got it hone yesterday...found a few things wrong with it. first, it leaks oil pretty bad out of the front seal (just got done replacing that about 10 minutes ago. NO LEAKS!) now i gotta remember how the PTO goes back together.
the trunnion on this is SHOT. needs to be rebuilt. hopefully it goes better than the 1450 i had. ill try to get pics when shes all back together. i washed about 20lbs of grease, oil, dirt and grime off of it before it came home....then got into the engine compartment and washed another 10lbs out. haha. runs perfect. the PO before me was nice enough to write down the hours and date of EVERY oil change since the new 18hp magnum was put in it in 1995. so thats cool.
Old 06-16-2012, 02:40 PM
Congrats, look forward to seeing pics of it.
Old 06-16-2012, 05:34 PM
another update....to my surprise....the trunnion is fixed. i welded a piece of keystock to the outside to basically remake the outside edge and it worked. hydro is nice and smooth. im going to drain the fluid and put a new filter and fluid in before i use it much more. but its a slick machine. the hour meter....at 2789 hours...still works.
Old 06-16-2012, 09:55 PM
Glad you got the 782! Looking forward to your pics.
