Old 04-02-2009, 09:40 PM
Bryan_Lively Bryan_Lively is offline
Default 1250 PTO problem
Have a 1250 with a PTO issue, and looking through the archives I cant find a similar case or Im not looking hard enough. The PTO clutch won't shut off, runs constantly. It will quit turning in heavy grass if Ive forgotten to switch it on when I start using it. Certainly dont like using it in this condition. Any ideas, solutions? Thanks for any help.
Old 04-02-2009, 10:27 PM
murphycc
Guest
Posts: n/a
My guess is it's one of 3 things.
Bearing is locked up or bad.
Switch is not shuting off.
The two pieces are bolted up too tight. If the springs over the bolts look compressed then back the nuts off a bit.
Scott
Old 04-02-2009, 10:31 PM
Jim H.'s Avatar
Jim H. Jim H. is offline
You may have full time power if wireing is messed up a little and magnet is holding it engaged.
Did someone mess with the airspace needed to disengage the clutch ?
It should be around .004 I have set it as loose as .012 and worked fine.
Every time I find the key to success, someone changes the lock
Old 04-03-2009, 07:05 AM
That seems awfully tight. I think my manual says 0.015-0.017".
Old 04-03-2009, 07:08 AM
The problem as previously stated, falls into two categories. It is either Electrical or Mechanical. To eliminate one, simply disconnect the wire going to the Elec PTO Clutch. If the problem persists, then it is a mechanical problem. If not. trace down the electrical problem.
Old 04-03-2009, 08:02 AM
Jim H.'s Avatar
Here is Rolands fine drawing and spec.
http://www.onlycubcadets.net/forum/showthread.php?t=30
Old 04-03-2009, 08:34 AM
aagitch's Avatar
aagitch aagitch is offline
I'd bet the gap is set wrong. The gap is too small and it's grabbing even when the pto is off but when you go in thick grass with the switch off, the pulley will start to slow down and stop.
Old 04-04-2009, 09:12 PM
Thanks folks. I found out it was the bearing, swapped one out, set the gap...works beautifully. I can let the wife use it now
Old 04-04-2009, 11:51 PM
Great job Bryan!
