Old 07-13-2012, 10:16 AM
Iowa Farmboy Iowa Farmboy is offline
Default 2072 front bearing
My front pto bearing has eaten her cookies. I have removed the front bolt and have tryed to pry the pulley off but have had no luck. I'm thinking I'm missing something. Could anybody tell me what I'm missing?
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 07-13-2012, 11:32 AM
Darrell Darrell is offline
There are four more bolts that bolt the clutch assembly to the engine. Remove those bolts and the PTO clutch slides off the crank and you can take the clutch apart.
Old 07-13-2012, 11:51 AM
SumBum's Avatar
SumBum SumBum is offline
The gold colored drum brake with the 3 spring loaded bolts are holding that pulley on.
Old 07-13-2012, 12:36 PM
Gaden's Avatar
Gaden Gaden is offline
If you tried removing the pulley without first removing the brake drum (looks like a shroud) you may have bent the springs behind the pulley. If so, reattaching the pulley will leave no gap between the clutch plates and the pto will be always on. The only fix is a new armature, close to 300 bucks. I really hope this isn't the case for you, just a heads up.
