Hello, im installing a new wire harness on my cub 128 and im having no problems but it appears that the neutral safety switch and the pto safety switch are no longer on the tractor. can I overide these switches? how would I go about doing this?
Thanks |
It would be better to purchase new or used safety switches as we do not condone the bypassing of safety switches intended to keep the operator and others safe. ...
I also would recommend to install at least the clutch switch it is a simple two
wire switch that is closed when you push the clutch---
Does anybody have pics of these switches installed? I believe I have the neutral safety switch on another cub its right next to the key and has a light bulb in it is that it? also i dont really plan to mow with this cub as I have a tractor better suited for mowing.
