Old 11-08-2009, 08:50 PM
cvcman cvcman is offline
Default help makin my own spring assist
Ok I figure if I know he length, daameter and wire size of the spring I can make my own. Anyone done this ?? Anyone know the dimensions ??
How does it attach to the lift arm ??
Thx
Cub Cadet 126
Old 11-08-2009, 08:55 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Thx
Would it be correct to assume it is for a narrow frame?
Old 11-08-2009, 09:20 PM
yup 126, sorry
Cub Cadet 126
Old 11-09-2009, 10:14 AM
RPalmer's Avatar
yup 126, sorry
I don't know that I can give you the measurements. There is one last question.
Do you want it to be "independent"? Meaning a lift bar for a 3 point is not needed. Or do you want it to attach to the 3 point? I think an automotive hood spring would work on either. But I'm clueless as to model, year, ect. I will tell you that when I looked at them I thought I knew about how big the spring was. After getting one I was very surprised to see how big it actually was. In my book it qualifies as honkin' huge.
Old 11-09-2009, 02:43 PM
the one I saw was not that big, the dia of the wire was pretty big. I dont have a 3 point so not sure what you mean. I want it to assist in lifting the snowblower so I assume it attaches to the lift lever arm ???
Cub Cadet 126
Old 11-09-2009, 03:32 PM
RPalmer's Avatar
I would have to take mine off to measure it. And I'm not going to do that. Here is a picture of what you want. I know you want measurements.. but I can't give them. I hope this somehow helps.
Old 11-09-2009, 07:16 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Rpalmer, when you say "Hood hinge spring", are you talking 70's to 80's chevy truck hood spring size, 73' Eldorado spring, or smaller like a 69' camaro?
Fly Fishing is not a sport...It's a way of life.
Old 11-09-2009, 07:28 PM
RPalmer's Avatar
I hope someone will be able to measure one for you. I'm gonna guess and say the spring is about 1 1/4" across.
Old 11-10-2009, 07:20 AM
jamesm jamesm is offline
I use a trip spring off a front snow blade. Just remove one of the ends and weld in a nut and your done. The springs are the same except for the loop in the end.
Old 11-10-2009, 07:35 AM
Mountain Heritage's Avatar
http://www.kinze.com/binaries/pdf/op...MECHANICAL.pdf
Perhaps you could adapt one of the press wheel springs to work for your application?? They have a hook at the one end and then a nut at the other so you could thread your rod into it. These are available at John Deere dealers or White dealers. They are used in lots of places on corn planters - different lengths and sizes. Just a shot in the dark?
