Old 07-26-2012, 08:52 PM
gregfromny's Avatar
gregfromny gregfromny is offline
Default wheel weights
how many bolts do you guys use to mount your wheel weights on the rims? pics might help thanks.
Old 07-26-2012, 08:59 PM
I use 2 on each wheel.When I put 2 or more sets on I use 4 per wheel
Old 07-26-2012, 09:06 PM
gregfromny's Avatar
ok do you use bolts or threaded rod? and why?
Old 07-26-2012, 09:22 PM
I use carriage bolts because I have a lot of them...
Old 07-26-2012, 10:14 PM
I use 1/2" carriage bolts too but I had to purchase mine at Home Depot.
Two bolts hold these 65 lb gulson weights on just fine
click
Old 07-26-2012, 11:36 PM
I just use 2 carriage bolts per wheel also.
Old 07-27-2012, 01:27 AM
I like carriage bolts as well makes installing them easier. I use 4 on each side.
Old 07-27-2012, 09:45 AM
I do the exact same as darkminion_17. Two hold fine, so it really is just a matter of preference.
Old 07-27-2012, 10:42 AM
gregfromny's Avatar
ok i wasnt sure i have seen a lot with the 2 or 4 setup just wasnt sure if there was a reason they did that or not
