Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 08-05-2012, 08:09 AM
MikeC MikeC is offline
Default Why do I need fuel solenoid on B&S
Got a B&S 12 hp twin with fuel problem.
Got carb kit, clean carb, put in new kit for carb and fuel pump. Same problem.
Check solenoid, got 12 volts, plunger not seized, so remove solenoid and plug hole. Everything runs fine.
So my question is What is the down side of running without solenoid? What does it do?
New one anywhere from $50 - $72 without shipping. Carb is a 404707.
Thanks, MikeC
"It isn't bragging if you've done it."
Old 08-05-2012, 08:59 AM
It was designed to stop Dieseling/run-on when shutting off, thus lowering overall emissions
Old 08-05-2012, 09:44 AM
Keeps the EPA turds happy
Old 08-05-2012, 11:44 AM
Merk Merk is offline
It doesn't have a thing to do with emissions...Briggs figured out a system to shut fuel off to the carb so you don't have fuel/flooding problems.
I have a friend who try to start his IH 460 farm tractor last week. Barn had a fuel smell inside the building. When the tractor started the whole barn caught on fire. He has 2 degree burns on his hands and face. He lost 2 semi-grain trailers, grain cart, big 4 wheel drive trator and the IH 460 tractor.
Yes you can run without fuel solenoid.....Is your building, tractor and your life worth $72?????????????
Old 08-05-2012, 12:54 PM
Thanks for the answers. It's not so much the money as it is about trouble shooting what is going on with the engine. Plugged it w/ brass plug, and it ran great. Ah ha I said, that's the problem, until I put a load on it. It bogged down under load, but not as much.
So I was wondering if the solenoid did more than cut emissions or stopped the dieseling.
Now I'm back to what's next. A bit stumped.
Old 08-05-2012, 02:04 PM
cubby102's Avatar
cubby102 cubby102 is offline
Yea all it did was shut the fuel supply off. I had one on a old junker lawn mower. I cut off the plunged in and put a fuel shut off in line
Old 08-05-2012, 02:43 PM
Sorry to hear of your friends fire, but the EPA in part, did mandate it with their requirements to be in compliance.
It lowers overall emissions by cutting the fuel on an engine that is being stopped, also tends to stop the raw fuel from being put into a hot muffler, on shutdown causing a back fire, which briggs had problems with.
It is not a "fuel shutoff" it only keeps the fuel in the carb bowel, from being sucked into the venturi.
If the float controlled needle fails to shut off, the carb will still flood and piddle gas out till the tank is depleated of fuel with or without the sol. valve.
But what do I know.
Old 08-05-2012, 04:10 PM
But what do I know.
You got it. It only shuts off fuel to the main jet. Briggs is not the only engine with it also. I have them on my Kohlers and my Kubota gas engine.
Old 08-05-2012, 06:27 PM
Need to read this:
http://www.briggsandstratton.com/sup...re%20solenoid/
First sentence proves my point.
Reasons for backfire:
http://www.briggsandstratton.com/sup...ting+-+Repairs
Main reasons are shutting engine at high rpm, muffler and carb adjustments.
Old 08-05-2012, 07:26 PM
I agree with the first sentence, it indeed shuts off the fuel, but only to to the venturi from the bowl.
it does not stop the fuel TO the float bowl before the needle valve.
I have one on my 806 gas that was built in '64 it was before emission requirements, it stopped the run-on that occured when shutting down an hot engine.(mostly) as they do not always shut/seat tightly
If the float controlled needle valve sticks/held open for any reason, it leaks fuel from the carb.
It is always a good practice to shut off the fuel shutoff valve under the tank on a gravity feed system
BTDT.
