Old 08-06-2012, 12:49 PM
MFP8055 MFP8055 is offline
Default Throttle slips
I've got a 1210 that will slip from wide open throttle to a lower speed while running. It it runs great at high speed (3000 RPM) with no vibration. As it slows, I first notice a little more shake, and then have to open the throttle again. I don't see any obvious tension adjustment at either the lever or engine end. I imagine this is a fairly standard component since it looks real similar to the one on my 1650. Any advice is appreciated.
IH 1650, CC 1210, 1610 and Bolens 1257
Old 08-06-2012, 02:16 PM
Sounds like the throttle cable is slipping to me.
Old 08-06-2012, 02:41 PM
ajgross ajgross is offline
Inactive Member
You probably nee to either replace the throttle cable or take the lever out of the dash and try to give the rivet a good whack with a hammer and tighten it back up.
AJ
Old 08-06-2012, 07:47 PM
CubDieselFan's Avatar
AJ
Yep, what AJ said....
Old 08-08-2012, 09:03 AM
The cable is in good shape and not slipping. It's the throttle lever that slides down from full open to mid-range when operating. Sounds like a job for a big hammer. Thought i could get away without pulling the fuel tank and removing the speed control. Wishful thinking on my part.
