Old 08-07-2012, 10:51 AM
340demon's Avatar
340demon 340demon is offline
you guys ever use Evapo-Rust? Got it at harbor frieght works on gun bluing too. When its used up just dump it biodegradable no fumes. Heres some pics of heater core after 48 hrs. But being safe it's probably not as cheap. I just use old plastic bins. Just a thought.http://www.onlycubcadets.net/forum/i...s/Biggrin2.gif
Sam
My Cubs
108 & 1250 & 104
Tiller, snow thrower,
Plow
Old 08-12-2012, 02:16 PM
EarlJ's Avatar
EarlJ EarlJ is offline
I use a couple differnt vessels 5 gal bucket, old cooler, and big rubbermaid tub. As for the catylyst all I use is arm and hammer detergent. For the wire I have been using copper ground wire only because thats what I have lying around. It works pretty good, just have to leave in the mix a little longer. When done I can simply dump it down the drain or pour in the yard behind the shed.
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-14-2012, 01:23 PM
jcsmith jcsmith is offline
thanks EarlJ, I ended up using electric fence wire ( had a spool laying around ), it's working great, Also used TSP, working great. I read here that TSP anodise's the part also. It must do something 'cuz the clean parts still haven't started rusting several days later. BTW, do you know if the battery charger puts out more amps the bigger the piece to be cleaned ? Thanks again, Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
