Old 08-08-2012, 10:29 AM
jcsmith jcsmith is offline
Default Early or late 42" deck?
My 42" deck ID tag is 421U1111 with a 2 stamped over the last digit. It has the cast iron front center section with wooden roller. It was on my 104 when I bought it. Is it an early or late deck. Any thoughts? Thanks, Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 08-08-2012, 10:34 AM
chris, we have alot of decks im not sure if that deck is an early one tho
Old 08-08-2012, 10:38 AM
mrcubcadet's Avatar
First, are we talking a "pin-on", or "quick attach" deck?
-105___ Tiller
Old 08-08-2012, 10:52 AM
That ia a qa. There are 5 different versions of the 42" deck.Hence the last number on the serial is 2 so it is an early one.
got 's any of them there pictures?
Up to 534 and counting...
Old 08-08-2012, 10:15 PM
Default 42" deck
darkminion, thanks for the info. Do all 42" decks have 2 short blades ,1 long blade. What about spindles,same or different. Thanks, Chris
Old 08-09-2012, 06:20 AM
How about some pictures....??
Old 08-09-2012, 10:50 PM
The only difference I have seen on the other variations is that the pins on the rear qa have spacers under them, a grease zerk was added to the idler pulley bolt,and the cast nose is different.The blades remain the same.The spindles are interchangeable with the 44 and 50a decks.
Old 08-10-2012, 01:14 PM
Thanks again darkminion. I'm not much of computer wiz, but I'll try get some pictures fellas.
Old 07-11-2015, 12:14 PM
chadwick404 chadwick404 is offline
hi all - i have the same deck, with no "2" overstamped at the end, just "421U1111" deck. I am attempting to level it and although I am pretty mechanically inclined I am just not seeing a straightforward way to do this. I am hoping you can help with my questions.
First, is there a true step-by-step procedure written anywhere I can follow? These old decks would strike me as not ever being true enough for the limited up front hangers to adjust well enough - am I wrong? Any youtube videos would be awesome, actually, to show how to do this on old decks.
Second, what are the blade sizes? I have a deck manual and can't find any mention of the blades sizes.
Third, is there any "kit" or suggested set of parts I could replace with adjustable versions to make leveling much simpler? It appears I have to remove the deck every time I wish to turn the hanging links - is this correct? Is there any aftermarket suggested part to eliminate this? I recall a suggestion of replacing a back attachment point with an adjustable version (vs adding washers which seem to stress the deck) - does anyone have a part number?
Lastly, does anyone suggest a replacement blade option (like Gator blades)?
Thanks to all who answer, and I appreciate your patience. I bought a restored 123 model to do actual work with it and altho I love the old iron they do have their quirks compared to many modern mowers...
How can I upload pictures directly?
Old 07-11-2015, 12:30 PM
timbo2's Avatar
timbo2 timbo2 is offline
To upload photos I use photobucket. There is a free version. I have the android app on my phone too. upload your pics there and you can copy them into your posts-
- Tim
