Old 08-01-2012, 10:23 PM
Default Cable Lift instead of Lift Rod Picture
Here is a quick picture of a cable lift to replace a lift rod on my 149 with a QA42A snowblower. The space between the lift arm and the mounting bracket in the front was too small for a lift rod, so this is what I came up with for under $4.
Old 08-01-2012, 10:31 PM
mrcubcadet's Avatar
Cub Cadet 123 told me about this setup when I first got my QA42A...It really does work great, and is much cheaper/easier than making a lift bar!
-105___ Tiller
Old 08-04-2012, 11:34 PM
cmatthew's Avatar
cmatthew cmatthew is offline
i done did the same thing with my qa42a on my 123 when i first got the blower. came without lift rod. the cable worked good until i fab'd my own rod.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 08-05-2012, 10:33 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I think i would but a bushing in the holes for the cable to go through that way you don't ruin the lift arms. Just my $.02
Old 08-06-2012, 02:03 AM
fleetlines's Avatar
fleetlines fleetlines is offline
Last winter I used a cable on a dozer blade and cut the cable in short order. I would also recommend the grommet if not the rod. I suppose the blade had more vertical movement than a thrower.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 08-08-2012, 05:07 PM
Flatbedford's Avatar
I put this together with some stuff I had around the house when I started plowing with my 125. It is 1/4 aircraft cable. I attached to the blade and lift with shackles so I could remove it quickly. It is much better for pushing snow that the rod could ever be. It always floats.
Steve,
Former multiple 149 owner.
Old 08-09-2012, 11:43 PM
I've only used it for my throwers and not for my blades since I always seem to have a rod lying around for them. I'll have to give it a try since it does seem like it would float a little better.
The bad/good news is that a day after posting this, I discovered that the 149 (pictured) is going to need a new piston and rings and maybe a bore job. There is just too much slop in it and too much oil in the head after removal to inspect the head gasket. Well, it will run better than ever since I've had it when it's done!
