Old 08-10-2012, 12:45 PM
ksanders ksanders is offline
Default Another 169
Went today to look at a 169. Didn't really want another tractor in the least but it was 5 miles from me. Turned out to be a basket case. Rebuilt 16hp was actually a slightly smoking 12hp with a new head gasket and a few ignition parts . Also no headlight, pto clutch had a bolt used at the pto button and wore the thrust button, no hour meter, gas tank and dash pedestal junk and not specific 169 parts. It did have the correct serial number and hydro lift so I went ahead and bought it. Can't decide if I really want to put several hundreds into parts and restore it but probably will. I have a parts 129 to lessen the blow so I'll do something with it after I convert it back to a starter/generator. This is my 3rd 169 and the last one was fully redone.
Preserving history... one Cub at a time.
Old 08-10-2012, 12:54 PM
Nice find, Kevin! It'll be right after you're done with it.
Old 08-10-2012, 01:02 PM
nice 169 kevin they are nice cubs
Old 08-10-2012, 03:24 PM
ajgross ajgross is offline
Inactive Member
Just what Kevin needs. Another tractor. Didn't you just sell a bunch because you had too many?
Anyway, good luck with it. BTW, are you coming up to Noblesville in Oct.?
AJ
Old 08-10-2012, 04:01 PM
Yes AJ I'm working on selling a bunch off. If this wasn't a 169 I wouldn't have brought it home no matter how cheap it was. No idea on Noblesville yet. If I don't start working less hours I probably won't be able to.
Thanks guys. I'll fix it up. Frame is cracked everywhere and needs a ground up restoration with quite a few sheet metal and mechanical parts to be great again.
Old 08-10-2012, 09:29 PM
Excellent find!! A rare 169 that's going to get some well deserved TLC.
Old 08-10-2012, 09:36 PM
mrcubcadet's Avatar
Great find, Kevin!
-105___ Tiller
Old 08-10-2012, 10:04 PM
I don't see any 169's around here.
Nice find Kevin
Up to 534 and counting...
Old 08-10-2012, 11:32 PM
red56turbo's Avatar
Kevin,
Nice save. Looks and sounds like it needs a little TLC, but if anyone can get her back together, it would be you.
Lew,
There's a 169 for sale on the forum. I could line up reverse shipping for ya like we did on the #2. That 169 needs a little more TLC though.
Josh
Diesel Cub Cadets...........
Old 08-11-2012, 09:23 AM
Thanks guys. Whatever could be worn out or rigged up on it is. I've never seen a frame broke in so many areas. There's cracks right in the middle of the frame in spots. I have this 129 I couldn't sell whole and am parting. I think I'll keep the frame, dash tower, and some part from it, swap the tag to it and get it painted then as I have time start fixing stuff and swapping it over as I have time. In a few months or or maybe I'll have a fixed up 169 that's actually respectable again... then park it in the shed with the others
