ditto, I just fixed a J.D. with this problem. Bad/burnt connections on the key switch
Ok guys, i checked the wire from the points to the coil and I couldn't find any bare spots
. I changed the plug wire for kicks and that didn't help either. I checked the plug on the ignition switch and that was tight but I cleaned up the connections anyway. While I was driving over the spots itusually sputters I tried at half throttle full speed and it didn't miss a beat. I'm leaning towards the float spring mentioned earlier in the thread.
1973 Model 149 42" Snow Blade John Deere X360 John Deere 10 cu Poly cart Squire Applegate 5HP recoil start ![]()
sounds like you've ruled out the easy stuff...I guess if CC has a spring part they must have had an issue...as far as I can figure, if everything else in the carb is ok (particularly the main jet), I guess the float bouncing could starve the fuel bowl at full load. but I'll shut-up and let the experts opine.
Run it in the dark and watch for either a spark jump to ground, or a loose ground. It sounds like the ignition is grounding out when you hit a bump.
Sounds very much like an electrical problem to me also.
Hope you get it tracked down.
I can see that there's been a lot of suggestions, but I'm going to throw in one that happened to me. make sure your condenser isn't mounted loosely; mine had loosened up a bit and bumps and vibrations made the engine skip and sputter. it drove me nuts trying to find the problem. once I snugged it up, problem vanished!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors!
Part of that "grounding" thing I alluded to earlier. I had my 1250 in storage for a few years and couldn't get it to run. Did all the fuel cleaning etc. Then pulled the wiring diagram from here and started to trace all that stuff removing/cleaning/reconnecting all the grounds. Battery to frame was easy...on the 1250 there is another heavy ground wire from one of the starter bolts to the front of the frame. Rather than list all the components that need a good ground (there are a ton of them), pull the wiring diagram.
Where switches are involved, a squirt of WD40 followed by a little "time out" will suffice I think. But where the ground involves a mechanical connection (like the condenser), remove, clean, reconnect. So the 1250 is running great (38 years old now). I think the problem was that the wire connected to the points was a bit loose (points on that machine are a major PITA) but I'll never really know since I cleaned all of the other major grounds at the same time. |
the spring keeps the float level ,so you won,t rin out of fuel
I tried to install the spring I purchased from kohler under the float today. I installed it with the larger diameter side of the spring under the float and the smaller diameter of the spring sitting on the bowl. This made it run worse. The governor was hunting really bad. Do I also need to re adjust the carb now? Being an add on part, no directions were included. I went through every wire having to do with the ignition again and still cant find any loose connections or bare wires. Thanks, Mark
Reading through the whole topic, you've gotten a lot of great ideas to check. IMHO, it doesn't sound like a fuel problem. Hitting a bump shouldn't starve the motor of fuel. Not vapor locking cause it only happens on bumps. Has to be something electrical. And believe me, an electrical problem can be frustrating to find. Have you checked the condensor yet to make sure it's tight? Otherwise, take some time and look at all the wiring and check for loose or rusted connections. Also check the wiring in the wiring harness clips. Sometimes vibration over the years can wear through the wire and if it's still in the wire clip, you might not see it unless you pull it out of the clip. You can also pull off the point cover and check the wire in there to make sure nothings amiss. Good luck and stick with it. You'll find the problem eventually.
Josh Diesel Cub Cadets........... |
