Old 07-27-2012, 07:36 AM
hiliary hiliary is offline
Default PTO Button
Went out to mow last night with the 149 and found that the original PTO button was broken. Luckily I had about a dozen brass 1/4-20 x 1" bolts from a previous project. Put one in the bracket and double nutted on the backside.
Old 07-27-2012, 08:57 AM
Sounds like a good fix. How about some pics?
Old 07-27-2012, 11:08 AM
Ditto.
Old 07-27-2012, 11:31 AM
How about a nice OCC welcome first!
Old 07-27-2012, 04:47 PM
Talking
Hello everyone! Here ya go
Old 08-30-2012, 10:48 PM
ty stroudsburg ty stroudsburg is offline
Why are the Cub ones non-metal? Won't this tear up your PTO in time? Just wondering.
Old 08-31-2012, 08:22 AM
PaulS's Avatar
PaulS PaulS is offline
I am no engineer but if I were then I would want one of those buttons to be more wearable than the other as there is a great deal of friction involved in stopping the pto. The one that wears down needs to be easily replaced so the logical one to make of fiber is the one on the outside rather than the one interconnected to various parts of the pto. Using metal for both will eventually wear the one connected to the pto and require removal of the pto to get that one out. If a bolt is found that is much softer than the steel one in the pto then it too should work.
Old 09-14-2012, 12:36 AM
gardenpest's Avatar
gardenpest gardenpest is offline
brass should work fine.......... I wish someone would come up with a design
using a sealed bearing so it would run with the pto instead of sliding against it.
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
