Old 11-19-2009, 09:45 AM
MrChic's Avatar
MrChic MrChic is offline
Thanks Sam. Maybe if the wheels are screwed up it will be a good excuse to do a 1 inch spindle up grade. The more I get into this Cub the more I want to fix it up. I guess that is how it all starts.
Mike
1968 CC 105
"Chug a lug a luggin' 5 miles an hour on my International Harvester"
"Don't forget that ignition key !!"
Old 11-19-2009, 10:15 AM
placeebo effect placeebo effect is offline
the rim looks like its from a windrow pickup wheel off a 914 pull-type combine
Scott Larson
Climax,MN
Its not cold. its gods way of keeping the rif-raf out.
Old 11-19-2009, 11:56 AM
MrChic's Avatar
Would the front rims be marked with a IH part number? I have to see if I can find one? I don't want to buy bearings if they won't work.
Mike
1968 CC 105
Old 11-19-2009, 04:29 PM
CubQuest CubQuest is offline
Just measure the ID of the bore in the hub. The OD of the bearings is .375 or 1-3/8". If it's just a little to big you can shrink it back down to fit the bearing.
Old 12-10-2009, 10:52 AM
MrChic's Avatar
Ok, so it seems my trade for a 71 fell through, so I will keep working on the problems with this 105. I have been looking for bearings and it seemed there are two types, a sealed bearing good for 500 hours, or an open back designed for grease penetration. So which is the better design? I have seen a wild price variation too, from about $7 to $13 for one bearing. There is also a set of four on epay for 25 bucks shipped for Cub pullers, anyone have experience with these?
Mike
1968 CC 105
Old 12-11-2009, 10:38 AM
MrChic's Avatar
Originally Posted by Wild Bill View Post
You want the sealed bearings.
BTW: In one of your prior posts you mentioned possibly 'doing the 1" spindle upgrade'. The 1" spindle upgrade is only available for Wide Frame Cub Cadets. You would have to fabricate your own 1" spindles for the 105 (Narrow Frame).
Bill, couldn't I just swap in an entire front axle with spindles and rims from a wide frame to get the 1 inch. I know you I need a later wide frame too. I am going to check the wheels and hopefully they are ok to just put in bearings for now.
Mike
1968 CC 105
Old 12-11-2009, 02:40 PM
Many people will tell you that you can't put a Wide Frame axle in a Narrow Frame tractor they will tell you that it makes the front end set too high and that it will make the front wheels set too wide.
BS! I did it to my 122 the wheels are exactly the same width from Wide to Narrow frame, and the height is only about 1/4" different between the two.
Truthfully though the fel on that 122 is pretty hard on the steering, the Wide Frame front axle, spindles and wheels are the only "Upgrade" that I have done to the steering. I did rebuild the column in it a few years ago, and I keep a spare rebuilt column on the shelf for it all the time, cause I know, at the most inconvienent time I'm gonna break the one that's in there.
BTW, I carry some pretty heavy loads with that thing, I move 55 gallon barrels full of motor oil with it all the time.
