Old 11-22-2009, 05:43 PM
I'm with jbollis...I think you've got them on inside out as well....I have MANY pairs of tire chains, and all appear to have been mounted with the openings out.
Old 11-22-2009, 06:09 PM
punkid's Avatar
punkid punkid is offline
What is better for the tractor as far as weight is concearned. I thought I read that Adding a lot of wheel weight adds a lot of stress to the driveline? I have also heard that adding fluid to the rear wheels is better then static weight to the rims. Theroy being the fluid moves within the rim and helps to cusions the shock.
I have cast weights on the the wheels of mine, plan on running chains when using my snowblower this winter. I was thinking if I need more weight to add it to the machine first.
1971 CC 107 with 42inch deck, QA36 thrower, 42 Blade, 36 Parker sweeper
Old 11-22-2009, 06:35 PM
Stitch's Avatar
Stitch Stitch is offline
My idea was just to buy free weights, drill holes in them, and bolt themon like normal wheele weights, will I be able to find anything to drill through them with?
Killin deers and drinkin beers
Old 11-22-2009, 07:31 PM
What's best for the tractor is to get the weight on the wheels so that the bearings are not carrying any extra loads. You've either got to have a higher horsepower engine or be doing something stupid to twist off an axle most of the time.
Old 11-23-2009, 07:11 PM
Stitch's Avatar
Here's another thought, what about rotors off some random car? With long machine bolts, you could put two on each wheel!
Old 11-23-2009, 10:00 PM
jbollis's Avatar
jbollis jbollis is offline
That is a good and easy idea,but I am wanting to put 100lbs or more on each wheel.
Sold everything but one.
Old 11-23-2009, 10:14 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Stitch, bench press weights are cast. Very soft, easy to drill.
I like that idea. I was planning on buying two 1'x1' plates of 3" thick lead.
cut the corners off so they fit in the center of the rim, then its simple to drill for the mounting bolts.
I can't remember the exact amnt, but you'll get like 70lbs per wheel, located almost dead on the axle flange.
The closer to the flange, the less outward flex, therefore the less stress on the axle.
Or, you want identical amount of weight on the inside, as well as the outside of the rim. This way, you can put an unlimited amount of weight on a wheel without adding any stress to the axle.
IE: the only weight on the axle, is that of the tractor.
Fly Fishing is not a sport...It's a way of life.
Old 11-07-2020, 03:04 PM
mikepeden mikepeden is offline
cool like this way mount weights
