Old 11-23-2009, 11:47 AM
dieselsnowmobile's Avatar
dieselsnowmobile dieselsnowmobile is offline
Default Heaviest Lawn Roller Anyone has Pulled
What is the weight of the heaviest lawn roller anyone has pulled with these Cub Cadets? I am thinking of making a lawn roller greater than 500 lbs, and just wonder how heavy is too heavy. I know I will need to have my tire chains on my 104 to be able to do it.
CC 104
Old 11-23-2009, 01:53 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Ask Dizjr., he's got the monster roller.
Fly Fishing is not a sport...It's a way of life.
Old 11-23-2009, 05:16 PM
mstetar's Avatar
mstetar mstetar is offline
i venture to say my cub cadet 71 (8hp) could pull over #1000 maybe more... but thats not your problem, its stoping, it you have any grade in your yard then its over, your brakes just arnt made to stop that kind of weight! and yes tire chains and weights would do you some good, lug tires would probably do just as good a job on turff without killing the yard!
check out my cub site
Old 11-23-2009, 06:05 PM
Merk Merk is offline
I pull 960 pound roller with my 149 on turfs....no chains.
Old 11-23-2009, 06:52 PM
"It a matter of weight ratio! A 5 ounce bird can not carry a 1 pound Coconut!!!"
Somebody asked this already, I never saw a real answer.....what's a cub weigh?
I've a 124.
Old 11-23-2009, 07:39 PM
jfinney's Avatar
jfinney jfinney is offline
eastonct124,
According to my cub cadet book, a 124 weighed in at 800 pounds (with a 175 pound operator and fuel). Puts it right around the 625 pound mark. jason
Old 11-23-2009, 07:50 PM
I have never rolled this one across the scales. But just the materials add up to 1000 lbs. And i love it. As i was finishing up building it i began to wonder if i had gone to big. Like the others said traction is going to be the issue. My yard is slopped but not any real big hills. The only time i spun out was trying to pull it up in front of the house. And you would not want to get into a spot where it was pushing you down hill. I had it out a few weeks ago and hooked it behind the 169 just to see what it would do. It pulls it a lot easier than the 149. But pulling it this time of year is different than pulling it in the early spring when the ground is extremly soft. It really does a nice job but it pulls harder because its sinking a little in the soft ground. But the yard was so much nicer this summer. I rolled some other yards with it and everyone said it was the smoothest they had ever seen it.
Old 11-23-2009, 08:12 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
That is the best movie.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 11-23-2009, 09:58 PM
Jfinney, thank you very much. I've been trying to fin an answer to that question since I've had it.
Much abliged.
-Richard
Old 11-23-2009, 10:22 PM
Yeah, but a 200 lb guy can push a 2000 lb car, just not very fast.
My yard is pretty level except for the bumps I want to roll out. My best estimate of lawn roller I want to make is going to be around 1,200 lbs. I used a concrete volume calculator and that is what it is saying. So, it sounds like it is doable but I probably will have feel it out. If the ground is to soft, I may have trouble pulling it and just have to wait.
CC 104
