Old 10-13-2012, 08:05 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default Engine Service 1863
Is there a consensus on weather fall or spring is the best time to change oil and filters on equipment. I have always done my Briggs v-twin LT's in the spring because mice like to build nest under the shroud during the winter. I have Castrol 10W-30 and Fram PH3614 filters on both Briggs engines and believe that filter would fit the Kohler CH but suspect that's not what most of you use.
Cannon
Old 10-23-2012, 11:22 PM
Dave01's Avatar
Dave01 Dave01 is offline
I assume you're not using the tractor in the winter. Fall is better, finish off the season, change the oil and filter, stabilize the gas or drain it, fog the engine, etc. I'm not sure I understand what the mice have to do with when you do the change?
I recommend you buy the correct Kohler filter from one of the parts suppliers. They are cheap enough and you don't have to wonder about all the cross-match details. In any case I'd suggest you get away from using Fram filters in anything.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 10-24-2012, 08:58 AM
Vince_o Vince_o is offline
Cannon
Here at the shop we use only air cooled oil and factory filters. The command likes to use oil and it has hydrlic lifters, they recomand 10 30 in it. The air cooled oil is higher in zink to help cool the cylinder. Where the oil you buy at auto zone ect is ok but when your running its at about 195 your air cooled eng will run close to 300 when mowing.
Your doing a good pratice of checking for mice, they will nest in the eng and block the cooling fins and over heat the eng and ruin it.
Old 10-24-2012, 08:53 PM
CubDieselFan's Avatar
Originally Posted by Vince_o View Post
Cannon
I have never heard of air cool oil, but it makes sense. What brand do you use? Thanks for the tip.
Old 10-24-2012, 10:43 PM
JayJay JayJay is offline
Default Low Ash Oil
I use the Cub Cadet Low Ash Oil available at the dealer or from on-line suppliers. It is formulated to keep deposits down that form from using oil designed for automobiles. I find it especially helpful to keep the valves from sticking.
Old 10-24-2012, 10:44 PM
Here is what my local Hustler dealer carries. I think it runs about $60 a case out the door. I can't find the Kohler 30 wt anywhere near me so this is what I use. As Vince said it has a higher zink content.
I have used the Kohler 10w-30 from TSC in my Command engines.
Old 10-25-2012, 06:49 AM
Cannon51's Avatar
I removed the muffler shield and air filter to try to see if there was any air obstruction. I was able to see the flywheel on one side so I used an air nozzle to blow the other side but never saw any nest trash. Since I have good air flow coming past the heads I am assuming there are no nest. I put the grill and hood back on yesterday after letting the paint dry a few days. I spent a while trying to get the hood adjusted so it hit right on the back but never got it perfect. haven't changed the oil yet so I may pick up some made for air cooled engines. Thanks
Cannon
Old 10-25-2012, 09:15 AM
Looking good, I have a 1863 that was my dads. They are very good machines. The last of the Real Cub Cadets IMO.
