Old 11-08-2012, 09:07 PM
ajgross ajgross is offline
Inactive Member
I do mean only the M18''s
AJ
Old 11-08-2012, 09:17 PM
Just kidding AJ. That is an Onan B48G out of a JD 420. I think the JD guys said that it blocked some of the airflow to the cylinder on the Onans. I think the remote mount is the way to go, although that fella up in Pickens SC has a Mag with the filter on the side of the engine.
Old 11-08-2012, 10:38 PM
cub1782's Avatar
cub1782 cub1782 is offline
I have a horizontal m18 out of a ford lgt 18h and the filter is coming off the block,I prefer it that way the hoses are another to go out and can be in the way.
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 11-09-2012, 06:05 PM
rwonder rwonder is offline
Right now, I am looking at the area under the gas tank. There looks to be enough room and all I will have to do is make a mt bracket and drill a couple holes in the firewall for the hoses. I do think it will make a nice looking installation. Supposed to be in the 70's tomorrow, so should be really nice working in the shop. Will let you know how this works or doesn't work.
Thanks for all the input.
Old 11-09-2012, 06:46 PM
Inactive Member
That's where they were mounted from the factory. I don't recommend drilling holes for the oil lines. I recommend doing what the factory did and just cut out a rectangle in the edge of the firewall for the lines to pass through.
AJ
