Old 11-27-2009, 07:43 PM
bobsinvt bobsinvt is offline
Question 1572 front wheel removal
Hi. Is there a trick in getting a front wheel off of a 1572 SGT? I've removed the single bolt/washer but the wheel seems to be stuck pretty tight. Appreciate any advice.
Old 11-28-2009, 09:46 AM
aagitch's Avatar
aagitch aagitch is offline
There shouldn't be anything else holding it on. It's probably just stuck.
Old 11-28-2009, 11:05 AM
ajgross ajgross is offline
Inactive Member
The trick is a block of wood on the backside of the rim and a sledge hammer. A couple of hits should knock it off.
AJ
Old 11-28-2009, 12:07 PM
Angry 1572 - front wheel stuck
AJ
Thanks for the tip. Still stuck after a lot of effort. Can I put a torch on the hub or could that ruin the bearings?
Old 12-07-2009, 04:32 PM
Thumbs up
Well, I've just removed the tire with the wheel on the tractor. Inserted a tube, which is what I needed to do, reset the tire on the wheel, and the tractor is good to go w/r to the front tires.
Tags
1572, front wheels
