Old 11-18-2012, 10:27 AM
Glad your making some good progress!
Old 11-18-2012, 10:14 PM
Thanks for the pics! Please keep the pics and updates coming.
Old 11-18-2012, 10:19 PM
You don't really need that baffle in front of the battery...in my experience that just makes the tractor run hotter.
Old 11-18-2012, 10:42 PM
red56turbo's Avatar
The progress is coming alot great. Keep the pics coming! I'm kinda curious on the rear end repair. My 782D I'm working on has the same repair (longer bolts with nuts). Will this hold up without problems with locktite and some sealer on the threads?
The mystery piece of sheet metal kinda looks like the heat shield for a 782 and the like.
Josh
Diesel Cub Cadets...........
Old 11-18-2012, 10:54 PM
Red contact Rich Patton via the banner at the top of the page he should be able to hook you up with your parts list.
Old 11-19-2012, 06:37 AM
dag1450 dag1450 is offline
Looking good, On the wiring at the rear end, Dont forget u have a seat safty switch and may b a pto option wire. As 4 the mystery sheet metal, the only thing on those tractors that even looks close would b around the fuel tank as a fender support. Maybe an air duct under by the engine insted of a screen. I have nothing on my 1572 that looks like that. Dave
Old 12-04-2012, 01:24 PM
Thanks for the update and looking forward to your pics.
Old 12-05-2012, 01:16 AM
72-149's Avatar
72-149 72-149 is offline
Originally Posted by jrarick View Post
I measured the clearance before I purchased a battery so I never used the 51.
The best(highest amp) I have found that would fit is the Interstate 340. If anyone has found a higher amp that fits it would be helpful to know-thanks
you can put one of these odyssey dry cell batterys they have them to fit up to 900 CCA. you can get one to fit a harley my shovel had a 900 CCA that was real small they have these batteryes on ebay too.click the Extreme Racing™ Specifications link once you get on the site & you know your meserments they have them up to 1200 CCA look up the PC 1200 that will fit your tractor & is 1200 CCA & they last 8-12 years !!! http://search.yahoo.com/r/_ylt=A0oG7...eybattery.com/
Old 01-08-2013, 09:41 AM
Originally Posted by Red Paint View Post
Long time, no post.
Well, I made a major step yesterday.
Parts came from Patton Acres a few days ago, and I ordered some Kubota stuff from the local dealership, which came in.
Got the radiator and grill installed, bolted on the seat, and did some other small stuff.
I understand why you guys call them smokers now! Took it for the maiden drive, and everything works like a charm. You can feel that power for sure! Can't wait to mow or plow with it.
I have two questions though:
1. When I hit the clutch, the tractor wants to back up slowly. Can this be related to the brakes in any way? One side of the brakes is worn so much that it will not stop the wheel, while the other side will.
2. What holds the radiator, other than the single top bolt to the grille frame? I understand that radiators aren't rigidly mounted (so they can float), but is that bolt the only thing?
The attached pics show the current status. There is still a lot of work to be done though, mainly in fixing a large amount of bad wiring. I will keep you guys posted on the progress.
Thanks all for your help, I am very happy so far.
Thanks for the update! Sounds like you'll have to adjust the brake linkage. Here's a guide on how to reline your brake pads from the tech section of the site. Looking forward to your updates!
http://www.onlycubcadets.net/forum/s...ead.php?t=1308
Old 01-08-2013, 10:22 AM
red56turbo's Avatar
Nice progress on the 1772.
On my 782D, there were also two bolts coming from under the frame screwing into the radiator. PITA to get out due to rust, ! Never had the rad out of my 1772, but should be the same as the 782D.
Sounds like you also need to adjust your hydro linkages as well. The clutch pedal is hooked up to the hydro linkages and may be tugging it slightly into reverse when depressed.
Josh
