Old 11-27-2012, 12:19 PM
jesse682's Avatar
jesse682 jesse682 is offline
Smile hydraulics for 1200
I recently bought a 1200 that I want to strictly use for plowing the garden and going to a few plow days. Im not really sure where and how to mount a cylinder or what kind of pump to use. Could I just use a power steering pump?
Old 11-27-2012, 02:09 PM
fhadderton's Avatar
fhadderton fhadderton is offline
whatever you find out let me know I've been wanting to do the same thing to my 149
Old 11-27-2012, 03:18 PM
ihnick's Avatar
ihnick ihnick is offline
Yes you can use a power steering pump. Since you wont need the pto clutch anymore, take it off and put a normal pulley on and mount the pump up there. Then get the hydraulic lift componets off of a1650 or 1450 and 8t will all bolt up. Just need to run lines from the pump to the valve and it will look close t8 a factory set up.
Fhadderton
Your 149 should have hydraulic lift from the factory
Nick.
Old 11-27-2012, 03:37 PM
fhadderton's Avatar
Ya my 149 is hyd lift but i was wanting to add hyd ports on the rear for running hyd cylinders on eqipment
Old 11-27-2012, 07:27 PM
ihnick's Avatar
You,ll just need to replace your valve with a 2 spool valve ans go from there
Nick.
Old 11-27-2012, 07:37 PM
jesse682's Avatar
Thanks for the tip!! Ill have to go hunt down some of these parts. With the lift components is that basically a 3 point?
[QUOTE=ihnick;161861]Yes you can use a power steering pump. Since you wont need the pto clutch anymore, take it off and put a normal pulley on and mount the pump up there. Then get the hydraulic lift componets off of a1650 or 1450 and 8t will all bolt up. Just need to run lines from the pump to the valve and it will look close t8 a factory set up.
Fhaddertonde
Your 149 should have hydraulic lift from the factory[/QUOTE]
Old 11-27-2012, 08:34 PM
fhadderton's Avatar
On my 149 could I put a T on my existing hyd lines and go to a hyd remote like the ones on the big row crop tractors ie. JD 4430. The only reason Im thinking that is I have a junk 4430 and 4020 to rob hyd parts from on my farm. The remotes are indedependent vales
Old 11-27-2012, 08:56 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
The JD valves are closed center valves and they would not work. Not to mention how big they are. You would not tee into the line you would run it in series with the other valve. I think the best bet would be to get a 2 spool from a 1650.
Old 11-27-2012, 09:53 PM
bruce s's Avatar
bruce s bruce s is offline
There are a couple threads about hydrolics in Customized cubs . Custom hydraulics on a 100 and rear hydraulic outlets . If you do a little searching you will find more . bruce s.
Old 11-27-2012, 09:59 PM
fhadderton's Avatar
Ok next question. Does the pump on my 149 flow enuf to handle a hyd motor? My plan has been to run a biger deck on the back that hooks up on the 3 pt and i have several spair hyd motors off of old implments( for those who might know...rod weeder motors) and I dont know what flow they need or whay the tractor puts out. Plus it would be nice to run hyd cylinders.
