Old 12-01-2012, 09:35 AM
deeseoid deeseoid is offline
Default Cub 127 Hydro
Newbie seeking info on use of attachments
Should I be able to use rear mount attachments(3pt. hitch) with the front plow blade hanger in place.
I have interference with the rear deck hanger pins and I don't know if that is because my plow blade hanger is bent or it is not designed to be used together.
Appreciate any response.
Old 12-01-2012, 09:59 AM
Muzzy Muzzy is offline
I had that problem on my 147. All I did was spread the back of the plow frame a little and it cleared.
Old 12-01-2012, 11:12 AM
I think if you lower one the other one lowers with it.
Old 12-01-2012, 12:45 PM
Old 12-02-2012, 07:43 PM
Default re: Cub 127
Thanks for the input folks. I straightened the plow hanger a little to give the same spread at the back as the front. Should solve the problem.
