Old 12-03-2012, 03:43 PM
rwairforce rwairforce is offline
Default 3 point comparison...application
Will a narrow frame 3 point fit all narrow frames?
Will a wide frame 3 point fit all wide frames?
I hope these questions haven't went over the stupid cliff but I've seen numerous listing indicating difference models that were applicable which forced these two questions from me.
Example...will a 3 point from a model 72 fit all narrow frames? Likewise, will a 3 point from a 149 fit all wide frames?
Thanks.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 12-03-2012, 05:10 PM
Basically, yes. The NF 3-point needs an additional bracket if it's being used on a 1x6/7. The WF 3-point is the same across the 86, 1x8/9 and QL series. The 82 series use different lift bars but are otherwise the same as the WF version.
Old 12-06-2012, 01:44 PM
Thanks Matt.
104 views and only your response. That surprises me, maybe everybody needed this answer or maybe nobody needed it...???? ahahahahah
Randy
John Deere 140 H3
Sears: GTV16
Old 12-06-2012, 04:38 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
I was one of those 104 views, but I don't know anything about WF's. So thank you for the info Matt.
- Cory Sanderson
Old 12-06-2012, 07:34 PM
Up to 154...
Seems like Matt hit the nail on the head.
I looked twice does it count as 2 or 1
