Old 12-16-2012, 08:34 PM
Inactive Member
Hey Sam! I should have thought of that... if I take that tube back off I'll be in for a mess! I suppose I could try a different tube... thanks!
Old 12-17-2012, 07:51 AM
Drain the oil back out. Remove the tube. Clean it up with some brake clean. Jack the front of the tractor up so any remaining oil run to the rear of the housing. Make sure the threads that the tube slides into are clean and dry. Make sure the nut on the tube turns nice and free. It took me a while to get this one loosened up. Start the tube into the housing. Put some sealant around the crush sleeve and some on the threads. Circled in red in pic. Push the tube all the way into the housing and get the fittings started. Make sure you don’t cross thread them. Tighten up the fittings and you should be good to go.
Old 12-17-2012, 11:15 AM
Inactive Member
Thanks! I like the idea of jacking the front up... didn't think of that one either! Maybe someday I'll get the hang of this obsession! The thing that baffles me the most is that I put the end you have circled in first and tightened it... the other end of the line was more than a .25" short. I managed to get the fitting together but wow... it wasn't easy!!
