Old 12-21-2012, 10:46 PM
444idi's Avatar
444idi 444idi is offline
Default No lights on the 782d
They were working great night before. Tonight nothing, just wondering if there is a common problem? The dash light is out too.
thanks
Old 12-21-2012, 11:22 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Are there no lights at all? Does the oil warning light come on when you turn the key to the on position with the engine NOT running? If so you could have a disconnected wire or bad headlight switch. If you do not have the oil warning light mentioned above, then you may be missing 12V due to a bad connection or bad key switch.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 12-22-2012, 10:41 AM
444idi's Avatar
the oil light does work but all others do not
Old 12-22-2012, 11:32 AM
Did you check your fuses?
Old 12-22-2012, 11:36 AM
444idi's Avatar
i think they are gone they are not in dash tower
Old 12-22-2012, 12:56 PM
FrankF3's Avatar
No fuses that I know of in the 782D, BUT there is an circuit breaker on the RH side of the tractor near the voltage regulator. However if you have the low oil pressure light you have power. The same power that feeds this oil light also feeds the headlights through the headlight switch. I would ohm out the headlight switch or CAREFULLY quickly jump it.
Old 12-22-2012, 01:34 PM
Sorry, I didn't catch it was a 782D. Looking at the wiring diagram, I am thinking a bad wiring connection.
Old 12-22-2012, 02:22 PM
444idi's Avatar
it was the switch thanks to all
Old 12-22-2012, 03:21 PM
Glad to hear you got it figured out!
Old 12-22-2012, 11:46 PM
Same here!
