Old 12-26-2012, 09:02 PM
Jumper Jumper is offline
Default 982 rear pto chipper
A couple years ago i got a hold of a chipper off a Jacobson and I modified it to fit the three point on my 982. My problem is finding a pto shaft that fits the tractor, any ideas on these 2000 rpm pto's ?
Old 12-26-2012, 09:28 PM
The guy I got my CC rear bush hog mower had to buy a new shaft because his was missing. He got it from a hardware that specialized in hard to find parts. You will need a male splinned yoke to fit into the female part on the tractor. I thought all 2000 rpm cat 0 shafts are the same, so another color of green or red may work. Nice 982!
Old 12-27-2012, 08:01 AM
nice 982
Old 12-27-2012, 08:32 AM
Just my 2 cents but I doubt that the rear PTO is strong enough to handle the chipper. I’m afraid you may damage the drive live. If it was me I’d fab up a mount to run it from the front of the tractor off the engine PTO.
Old 12-27-2012, 07:44 PM
lukeott lukeott is offline
Default I Agree
I agree with Sam Mac. Just not worth taking a chance. If you hook up to front pto and theres a problem, the belts will give. Cub cadet has them that work this way, would follow their design.
luke
Old 12-27-2012, 09:40 PM
Iowa Farmboy Iowa Farmboy is offline
There are belts in the rear pto so if it was to jam the belts would slip to protect it.
As far as that big of a load ...I would not hesitate as a 48" tiller running deep delivers a heavy load and nothing has broken on mine. Yet!
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 12-28-2012, 09:10 AM
bruce s's Avatar
bruce s bruce s is offline
I believe Baum Hydraulics has the right splined shaft . If your able to find a u-joint and pto shaft you can make your own. www.baumhydraulics.com or Mc Master -carr may have the shaft also. I have found it in a couple places some are pricey some are not.
Old 12-28-2012, 10:09 AM
They are not a chipper, but more of a hammer mill designed for leaf/small twigs, never liked mine so I gave it away.
Old 12-28-2012, 12:53 PM
Merk Merk is offline
Is the chipper designed for a 540 or 2000 rpm pto system? The chipper could self destruct if the system is designed for 540 system running on a 2000 rpm system.
Project Uncle Dick
Cub Cadet 70
Old 12-28-2012, 01:33 PM
Merk makes a good point. If it’s a 540 RPM chipper run at 2000 it could also come apart and kill you.
