Go Back   Only Cub Cadets > Off Topic > Suggestion box
Old 12-22-2012, 09:33 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default be able to upload DWG. files
i don't know if it would be posible or not to be able to make it so we can upload DWG files so like the other day i wanted to upload a drawing i had made to help another member and i couldn't change the file to a jpeg at my end so i took a pic and did it that way but was real clear.
Old 12-22-2012, 11:35 AM
Have you tried a converter program .... www.irfanview.com
Old 01-03-2013, 07:20 PM
racenitro racenitro is offline
There are a number of free FWG to PDF conversion progreams available.
Just convert the DWG file to a PDF.
DWG files are usually rather large and would not uploade easily.
Depending on the version of Autocad you may be able to save in different formats also.
Old 01-03-2013, 07:29 PM
samckitt samckitt is offline
Check to see if you have "snipping tool" on your machine. You can use that to grab screen images & save them as jpeg files.
