Old 01-13-2013, 03:28 PM
blacktie blacktie is offline
Default My Original resto
Here are a few pictures of my project... this is my first tractor restoration so I won't be moving as quickly as some of the veterans here... I tore this thing down before I took any "before" pictures, but I will share the "during" and "after" shots...
My first stumbling point are these pins holding in the clutch/brake lever and the one holding on the drive shaft.
any tips? thanks in advance, Eric
Old 01-13-2013, 04:29 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Tak a pair of vise grips and hold the break pedal from moving, then get a spirol pin punch (1/4" I believe) and drive them out. They make the special punches that work awesome, but normal drift punch will do the job too. Good luck with it, I am also restoring an O!
- Cory Sanderson
Old 01-13-2013, 04:32 PM
Looks like you have a good start.
Looking forward to more pictures of your work.
Old 01-13-2013, 04:49 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
those spiral wound roll pins are bad news to get out. when you go to put it back together get new pins. sold at any tractor dealer like Cub /JD. dont use a split roll pin, split roll pins and spiral wound roll pins are not the same.
Doug
Original , 100 , 125 , 582
Old 01-13-2013, 05:25 PM
jbrewer's Avatar
jbrewer jbrewer is offline
The one your driver is pointing to sure looks like a piece of solid rod.
Have you met PBblaster yet?
Looking forward to your work
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-13-2013, 05:26 PM
I knew you guys would know... I'll take a picture of my pile of parts if you would like
Old 01-13-2013, 07:03 PM
We like pictures
Old 01-13-2013, 07:20 PM
Your off to a great start!
Old 01-13-2013, 09:26 PM
methos... you are right down the road... I live in Sherrills Ford.
Old 01-13-2013, 10:14 PM
Thanks for the pics! Looking forward to your updates.
