Old 01-17-2013, 07:56 PM
I was thinking poor battery as well.
Old 01-17-2013, 07:59 PM
thomas 1863's Avatar
thomas 1863 thomas 1863 is offline
well i gota go to the farm store in a couple days any way i guess ill look in to a new battery what kind of cca should i be looking for it a 12 hp
Old 01-17-2013, 10:56 PM
cubby102's Avatar
cubby102 cubby102 is offline
The higher the better... I got a little 275 I think it is on ny 123 and does fine. Got a 360 on the original and can defntly tell the difference
Old 01-18-2013, 12:59 PM
X2 on the highest CCA you can get. I went to my local TSC and got this one; http://www.tractorsupply.com/mower-b...g-amps-4700042 it turns over my 14 HP well.
Other things I checked when I was having problems with mine:
grounds are all cleaned up, and tight.
Spark plug gap is correct
points are gapped correctly
I use 93 octane fuel in winter, it helps
park it inside, or get a heater for your rear end
I also put a batt. tender on my battery to ensure it's good before i want to start it.
Old 01-18-2013, 05:37 PM
BThein's Avatar
BThein BThein is offline
I would do as Matt says,make sure you points are good and do the static timing.I did not believe it till I tried it and now would not do anything else.The 123 I had would start so much better after ,like night and day.
Bob
Old 02-02-2013, 09:09 PM
new battery is in contacts on the battery are good haven't checked others yet and im still having the same problem
Old 02-04-2013, 02:41 PM
changed out the s/g and wow what a difference it cranks over so much faster now and starts right up
Old 02-04-2013, 02:54 PM
Glad you got it straightened out!
Old 02-04-2013, 03:07 PM
thanks also did a carb cleaning
Old 06-04-2020, 07:00 PM
tvag06 tvag06 is offline
My tractor, a 126, has this starting issue. What is this s/g you speak of?
IH CC 126 with 38" deck
