Mine are P rated on the 1500. But the are TRUCK/SUV/CUV tires. They are tougher than a car tire. They are rated for higher weights and pressure.
Roger,,109,1450,1210 ![]() Some Days all You Can Do Is Hang On!!! |
I put the BF Goodrich T/A KO on my wrangler, they ride smooth, quiet, and have good traction. Not the cheapest tire, but they have been making them for a while, and they are kevlar reinforced
The Suburban weights over 5,300lb 'dry' add oil, front and rear differential fluid, transfer case fluid, transmission fluid, and 42 gallons of gas....plus up to 9 passengers (not to mention XX lbs. of cargo, and XX lbs. of a trailer), and you get - I'm not putting anything less than LT rated tires on it.
Keep in mind, I don't want A-T tires/tread. Since I've bought the pickup truck, it sees the 'off road duty'. The Suburban will stay on the pavement from now on........
Original OCC Super Mod....and former OCC Co-Admin. I was hacked........ |
I ran a Cooper brand tire on my 99 Chevy Suburban. They had a highway tread and were a 6 ply tire. Traction wasn't a issue unless the 45 galion gas tank was almost empty and pavement was wet. I was getting 70000 to 80000 miles on a set of tires. The ride was good and the tires were quiet. I pulled a 30 foot camper and a 16 foot cargo trailer with my Suburban.
The Suburban was traded off on a new Chevy 2500 HD pickup last April.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Thanks Dale!
I did some more research on tires made by Cooper...and found the 'Mastercraft' brand. I'm leaning towards the Courser HTR, or the HSX Tour. I'm thinking Load Range C will be plenty, but they also offer a Load Range E in the LT245-75-16 size..............
Bill,
Glad to be some help. I think my tires were the Mastercraft brand. Suburban was traded for current truck last April. My Suburban had 15 inch tires. It was only a 2 wheel drive.
Load range E is 10 ply rated tire. The load rating is only meaningful if run at recommended PSI, which is 80PSI. On a 1500, the original rims may not be rated for that high pressure. Load range C should be more than adequate for you.
