Old 01-20-2013, 05:42 PM
blacktie blacktie is offline
Exclamation
got 'em out! thanks again. started rebuilding the steering column today.
Old 01-20-2013, 06:27 PM
here are some of the steering parts. took the wire wheel to them and then a coat of rust resolver.
Old 01-20-2013, 11:19 PM
Thanks for the update and pic.
Old 01-21-2013, 12:20 AM
Oh yeah and look good too!
Old 01-21-2013, 01:06 AM
Coming right along.
Great pictures
Old 01-30-2013, 03:28 PM
finished the rebuild on the steering column today and spent some time with the angle grinder...
Old 01-30-2013, 03:29 PM
Nice work! Thanks for the update and pics.
Old 01-30-2013, 07:46 PM
so I have ben having trouble getting the reduction drive shaft out. I would like to replace the bearings, and I think they are the reason I cant get them out. I tried pressing it out with my vise, no luck there. so I am thinking that I need an internal bearing puller, but I am having trouble finding one that will fit in this bearing lip. (yes the snap ring is out)
is this the right idea?
and if so, where can I get this magic tool?
Old 01-30-2013, 08:27 PM
AALDRICH AALDRICH is offline
Blacktie, Look for 2 snap rings. 1 on the shaft, and the 2nd on the bearing. after they're out... the shaft and bearing should tap out easy with a light hammer. Also Shaft seal IH377959 R91 is NLA. Haven't been able to find anyone who has the IH part. I did find Napa Seal NOS 7636 does fit, but it will leak a bit. If anyone has a line on any IH parts folks who has this IH seal, i could use one for my "O". Hope this helps. -AL.
Old 01-30-2013, 09:33 PM
AL, thanks for the input... They were both out. I'm not sure what is stopping it. the whole shaft and bearing slide about 1/2" out then it hits a hard stop. I'm wondering if I should just move on and let the shaft have a little wiggle room, esp. if there is going to be an issue finding replacement parts.
Eric
