Old 02-05-2013, 08:00 PM
Default checking an hour meter
Got this hour meter off the 125 and nor sure if it works or not because I haven't used the tractor yet.
I've got it out and was wondering if there is anyway to check it to see if it works?
Being there is a positive and neg. could I just hook it to a charger and see if it moves? In theory that's how they work when the power is put to them, right?
Thanks
Old 02-05-2013, 08:07 PM
Thanks
That or a battery should let you know if it works. You will need to sit and keep an eye on it for a couple hours. A cocktail will help pass the time.
Old 02-05-2013, 08:19 PM
Thanks Sam.
I'm pretty good at sittin'
Old 02-05-2013, 09:28 PM
Use a battery, not sure how a half wave rectifier in the charger will affect it.
they don't draw much, so no problem there.
hook it up, note time, come back in the morning and compare.
Old 02-05-2013, 10:18 PM
I got one of those for my 128 but I am going to have to fab the rear bracket for it. You happen to have a pic of that?
Old 02-05-2013, 11:08 PM
Like this?
http://www.partdeal.com/hourmeter-12-24-volt.html
Old 02-06-2013, 12:50 PM
Well I had it on the charger, (didn't check site since last night) this morning for three hours and nothing moved. Sooo, you think it's shot, or give the battery thing a try?
DWayne, the PO put mine in the hole then drilled holes around it and attached with screws and washers on the side. Pretty tacky!
Old 02-06-2013, 01:54 PM
Yep, that helps.
Old 02-07-2013, 06:26 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Try the battery. 40 years ago, I tried to use a battery charger as a power supply to run a timer in a autocross. Didn't work at all. Used a battery and the timer worked OK. Hour meter may be the same.
John
Old 02-14-2013, 09:57 PM
You should be able to put it to your ear and you will hear it tick.
