Old 02-08-2013, 05:59 PM
michael11 michael11 is offline
Maybe I should mention that there is a 1330 (?) down the road for about $200 Pretty rough though, and only comes with a mower deck...
Roger, I am on the other side of Toronto.. I am near Niagara Falls..
Seems like either one would be good. Having a 2 cyl wouldn't hurt either I suppose..
BTW - Thanks for making a stranger feel so welcome on thie forum !
Old 02-08-2013, 06:16 PM
I will want to hook up some brinly type attachments. So I will need a sleeve hitch....I think.
I guess I need still need to buy more parts to have a sleeve hitch.. correct?
See attached pics of hitch area on both tractors:
1450:
Uploaded with ImageShack.us
1811:
Old 02-08-2013, 10:12 PM
You'll need the Brinly adapter. The white piece in my pic. You'll also need the pin that goes into the top casting. You already have the top casting.
Old 02-09-2013, 01:11 AM
Shaner Shaner is offline
I'd go with the 1811 or jd318. Both are great. Though the jd has more options that are nice to have.
Old 02-09-2013, 01:58 AM
jacobd jacobd is offline
I'd also say the 1811 or the 318 mainly depending on what engine it has. You'll love the magnum 18 in the cub and the deere might have the same but if it has an onan I'd stay away. They both have the same hydro units although the deere has power steering. Assuming they both have kohler magnum engines I'd go with the tractor that's in the best condition.
Old 02-09-2013, 06:37 AM
If it is a 1330 I would stay away from it. It is just a lawn tractor and won't do what you want it to do!
Old 02-09-2013, 08:32 AM
Here is a pic of the tiller.
Looks like the pin is with it? Or is it a different pin?
Old 02-09-2013, 08:55 AM
As far as the JD 318 vs. the 1811.
Although the 318 does have some nice features... As far as a Brinly type sleeve hitch goes, I think it would be too costly to put together.
First, I'd need to buy the 3 pt. hitch setup at 300-400, then th a-frame type adapter at another $100+
The Cub Cadet has most of the pieces already..
Old 02-09-2013, 02:26 PM
Yes the tiller already has the top pin.
Old 02-09-2013, 02:36 PM
Nothing wrong with an Onan, great engines just ask the guys with the 982's
