Old 02-11-2013, 10:26 PM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Default Breather assembly
I started to put the breather together on my k241 that I am rebuilding. The seal that was provided with the rebuild kit was considerably longer and harder than the original seal, and did not seem to compress any. Also the kohler manual shows a baffle that goes between the breather plate and the vent cover. I dont seem to have this piece. The filter element fits snuggely when placed vertically, but does not cover the baffle holes unless placed horizontally. Without pulling another breather apart, can you guys comment on the baffle and filter placement?
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 02-12-2013, 06:26 AM
rmunro's Avatar
rmunro rmunro is offline
Try downloading the service manual. On page page 12-17, diagram 12-46. Show's parts and installation.
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 02-12-2013, 06:32 AM
rmunro's Avatar
Don't think that shortcut will work.
Will try again later.
Old 02-12-2013, 06:43 AM
This should help....
Old 02-12-2013, 07:47 AM
wj-ihc's Avatar
Ya, that is the same schematic that is in my Kohler manual. My breather plate "H" actually has a baffle on the back side of it, towards the valves, but no loose baffle to put between "H" and "B1".
Old 02-12-2013, 08:14 AM
The above, is the correct parts listing for the Cub Cadet version of a K241 - Spec 46179
Old 02-12-2013, 08:20 AM
rmunro's Avatar
I've only had 3 different engines apart, but all were like the schematic Roland provided.
Old 02-12-2013, 01:07 PM
wj-ihc's Avatar
Sounds like I'm gonna have to come up with some parts from one of my spare blocks. Thanks for the info.
Old 02-16-2013, 12:34 PM
wj-ihc's Avatar
Well I found a baffle in a parts engine and Im putting it together as the manual shows. Howeve, I have attached a few photos of the breather plate that has the baffle spot welded onto the back side, rather than being a separate piece as the manual shows. So I will end up with two baffles plates, which won't hurt anything as far as I can tell. Just thought it was interesting. Thanks for the help.
Old 02-16-2013, 02:32 PM
rmunro's Avatar
I'm no expert, but can't see how 2 baffles would hurt. May even help. You may have started a trend.
