Old 02-19-2013, 05:43 PM
mmzullo mmzullo is offline
Default Hydraulics for Haban Blade
Well it's done and worked out great. Now I have to get the blade painted. I've been saying that for 2 years now. I have more pictures of the set up. Part #'s to follow soon.
Old 02-20-2013, 08:42 AM
Can A moderator put this last post in the CCC section. I didn't realize it was in the wanted section. When it does there I will update pictures and rest of the mod.
Thanks
Old 02-20-2013, 11:20 AM
Thanks
Done please post more pics!
Old 02-20-2013, 01:12 PM
Looking forward to this, Mike!
Old 02-20-2013, 07:58 PM
cuber cuber is offline
How much did all the parts cost?
Old 02-21-2013, 09:37 AM
Here are the rest of the pictures. I only tacked welded the pins to the mounts until I had a good swing of the blade. The square block was the easiest but the pin had to go on a slight angle for some reason. The rear angle mount was the hardest but not too bad. I had to cut and weld it a couple times.
The piston is the same throw but when it's collapsed it an inch longer. That was no problem I put the pin on the other side of the bracket. That fixed that.
This was easy to to do but I had access to a trailer shop with all metal and tools to do most of the work. So all the hardware/metal was free.
List of parts.
2 - 1/4 inch hoses 24" long #916-1424 $6.00 ea
1- 8"x 13 1/2 cylinder # 9-4410-8 $98.00
2- 3/8 to 1/4 bushings brass $ 2.50 each
Power angle priceless!
All parts came from Surplus center.
The cylinder has 3/4 pin holes and rod diameter is 3/4 also. Port size is 3/8. This is bigger then the 5/8 rod that was there.
Good luck to who can use this info. If you need any help let me know.
So now I'll put the other set up in stock for future project(1650 dual ports).
POWER ANGLE IS THE WAY TO GO!!
Old 02-21-2013, 10:05 AM
Nice job Mike!
Alot cheaper then OEM!
Old 02-21-2013, 01:15 PM
Nice work, Mike! Thanks for the pics.
Old 02-21-2013, 05:52 PM
Congrats on a job well done!
Old 02-21-2013, 06:00 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Great post Mike and thank you for all of the details. This is valuable stuff buddy and I am sure that there are several members on here who can make use of your hard work.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
