Old 02-26-2013, 06:52 PM
gmiller442 gmiller442 is offline
Default K321 oil seal question
Can the crankshaft oil seals be changed without removing the crank from the engine? These seals seem like the could be pulled out and then pressed back in. I could be wrong? Any help is appreciated!!
Thank you,
Gmiller
Old 02-26-2013, 07:53 PM
Yep, as a matter of fact you have to set the seal depth with the crank already in place. Check out your Kohler service manual to get the correct depth. If you don't have one, they are located in our Tractor library.
Old 03-02-2013, 02:54 PM
jcrews's Avatar
jcrews jcrews is offline
Also make sure to polish the crankshaft with sand paper before installing new one I messed up the first one not doing that.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 03-04-2013, 10:24 PM
samiam44 samiam44 is offline
Order 2 seals if you've never done it before. The Kohler seal is quite thin and a bit tricky to get seated correct depth and square in the bore.
Michael
