Old 03-11-2013, 07:18 PM
aagitch's Avatar
aagitch aagitch is offline
Todd, love those tires on the smoker!
Adrian
2072 (789513)
Old 03-11-2013, 08:33 PM
Thanks Adrian. Tru Powers and V61's. I had to do a little test run for RNPD.
Old 03-11-2013, 08:44 PM
EricR's Avatar
EricR EricR is offline
Todd, how do you like those tru-powers? I'm going to replace mine on the 2086 and don't know which I want to go with, either those or the Firestones.
And nice pics also.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-11-2013, 10:15 PM
Thanks Eric. I can't say for sure because I had no weight on or in them but I know the Firestones are great. I did spin some but I need to adjust my plow and load the tires. It rained today so now I need to wait again.
Old 03-11-2013, 10:18 PM
I knew I had that coming Allen!
Had to pick on you some, Mike.
Old 03-12-2013, 06:24 AM
I know Allen. It's all in good fun!
Old 03-12-2013, 01:23 PM
That's right!
Old 03-12-2013, 05:50 PM
theunit's Avatar
theunit theunit is offline
Iv replaced both my axle seals and replaced two of the very rear frame bolts i thought were stripped. Luckily a p.o. had put shorter bolts in those holes and some of the threads were stripped, so i put longer ones in and they held tight! Also put a new rear cover gasket on but it is leaking at the bottom, so it needs pulld and looked at again.
Old 03-12-2013, 07:46 PM
EricR's Avatar
Thanks Todd. You will need to update us when you get them loaded as I'm counting on you,
Old 03-12-2013, 10:14 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Did some work on the 44A deck today, took the wire wheel and cleaned it up then put the rust sealer on.
